Re: Fuel tank venting question- 1966/1967 & 1972 Charge
[Re: Hazwoy]
#563035
12/27/09 05:47 PM
12/27/09 05:47 PM
Posts: 4,361 swamps of florida
beepsalot
swamps of florida
66/7 charger vents from the front of the tank, and runs up intothe 1/4. the 72 vents to a box over te axle, and yes sounds like the soldered joints went away in the 72 tank the gas cap change will work, necks are the same but the tanks are entirely different
Just Follow Me Down the Street, You'll Know i'm Up to No Good...
[Re: beepsalot]
#563037
12/28/09 08:51 AM
12/28/09 08:51 AM
Posts: 3,820 Arlington, Texas
bobby66
Arlington, Texas
My '66 Charger vents from a fitting at the left side rear of the tank. Goes through a couple elbows and a steel tube to the filler tube. Actual venting is done through the gas cap.
[Re: Hazwoy]
#563040
12/28/09 06:43 PM
12/28/09 06:43 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I have a few 72B tanks out. I'll check but I don't think that the 71-3B tanks have that hole in the center of the tank. 71-5/72 has the vent tubes on the drivers side of the tank. 6/72-73 has them on the front.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
