Page 12 of 21 1 2 10 11 12 13 14 20 21
Re: A66 [Re: ph23vo] #562813
02/18/10 09:29 PM
02/18/10 09:29 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
they are dealer installed is why dan
What was dealer installed ? mud flaps or wheel lip molding. All I know is the wheel lip molding screw holes look to put in with the same process as other cars I have had that were factory installed. Any other Hamtramck cars with mud flaps ? Hey Dan does your fender tag or B/S call out your rallye hood on your A66 ?
Re: A66 [Re: DetMatt] #562814
02/18/10 09:45 PM
02/18/10 09:45 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Y05 26 EN2
G33 M21 N41 N42 R11 V9X
V1X A01 A66 C16 C55 G31
FK5 H6K4 000 B13 016050
E55 D32 JH23H0Bxxxxxx
I fixed a couple details for you.
Hard to tell from the photos, but I do not see fender top turn signal indicators? You could not get them with A01 on the Challengers with the raisin bran hood, so it is my guess that your car did not have the flat hood.
Look for L31 on your broadcast sheet to confirm it one way or the other.
Re: A66 [Re: Alaskan_TA] #562815
02/18/10 09:46 PM
02/18/10 09:46 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Mud flaps were not a factory item on these cars.
Re: A66 [Re: Alaskan_TA] #562816
02/18/10 09:53 PM
02/18/10 09:53 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
hudson no sheet on mine sorry LA car.. seen those flaps on c bodies also no factory codes for them.. w/o mouldings were all installed the same way with a drill! dan
Re: A66 [Re: ph23vo] #562817
02/18/10 09:57 PM
02/18/10 09:57 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
no j54 on my fender tag
Re: A66 [Re: Alaskan_TA] #562818
02/18/10 10:51 PM
02/18/10 10:51 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Raisin bran hood is that the flat hood ? It says in the salesmans pocket guide that turn-signal indicators N/A with 340 and R/T ? I would think that ment with the J54 hood (Sport,Rallye )and cars with the flat hood would have them ? I agree and think the car above probably had a rallye hood from the fact it did not have the V-8 emblems on fenders and build date.
Re: A66 [Re: Beebuzzn] #562819
02/18/10 10:54 PM
02/18/10 10:54 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Raisin Bran - Two scoops.
Re: A66 [Re: Alaskan_TA] #562820
02/18/10 11:06 PM
02/18/10 11:06 PM
cataclysm80 Offline
cataclysm80  Offline
My 70 Cuda (Hamtramck) had those mud flaps when I got it. I think they are just a universal auto parts store item from back in the day. Helps keep the rocks off your quarters when doing burnouts.
Tav
Re: A66 [Re: DetMatt] #562821
02/18/10 11:09 PM
02/18/10 11:09 PM
cataclysm80 Offline
cataclysm80  Offline
More pics.
Notice the R/T badge. The R/T badges that were on the fenders were the stick-on type.
The stick on R/T badges are for 71 cars. Your fender tag shows a 1969 build date. Looks like your stick on R/T badges were added by a previous owner who probably got them over the counter at the dealership.
Tav
Re: A66 [Re: DetMatt] #562822
02/18/10 11:22 PM
02/18/10 11:22 PM
cataclysm80 Offline
cataclysm80  Offline
Hey thanks!. Yes it is original paint. The box for the wheel lip moldings is not checked on the build sheet but it's got them,... ...Maybe these things were added early on at the dealer.
The vast majority of Challengers came with wheel well moldings as standard equipment. They are indicated on a challenger broadcast sheet.
Some cars like the T/As & A66 cars, etc., were not supposed to come with the standard challenger wheel well moldings. Those cars do not have a wheel well molding code on the broadcast sheet. Anyway, if such a car that wasn't supposed to have the moldings, did actually recieve them (possibly yours), then it was simply a mistake at the factory, and would still not be coded on the sheet.
Wheel well moldings were not optional on Challengers, so there was no way to special order them back onto your car if it was supposed to come without them.
barracudas on the other hand had wheel well moldings as an option, so on those cars, the moldings could have been officially added at the factory.
Tav
Re: A66 [Re: cataclysm80] #562823
02/18/10 11:27 PM
02/18/10 11:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The vast majority of Challengers came with wheel well moldings as standard equipment. They are not indicated on a challenger broadcast sheet.
They are coded for Challengers that had them as standard equipment.
A66 cars & T/As have nothing in the wheel lip box.
Re: A66 [Re: Beebuzzn] #562824
02/19/10 12:29 AM
02/19/10 12:29 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
EV2A66, is your "pocket salesman book" the same version posted on Hamtramck-Historical?
I don't think there was a "J54" code for the "raisin bran" hood until it became a purchasable OPTION on the Barracuda. Winter time?
M26 on b'cast sheet, car has wheel lip mouldings. No M26 - NO mouldings. (unless it was a mistake)
No L31 on the FK5/V1X/V9X b'cast sheet.
Re: A66 [Re: 6bblgt] #562825
02/19/10 02:29 AM
02/19/10 02:29 AM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
That's what I'am getting at was there a J54 sport,raisin bran, rallye hood code on these cars early on ? you answered that. And yes I got my copy of the salesmans book (date ?) off the Hamtramck site. Thanks Barry But the first 4 months of these cars are all over the place. My car has a flat hood with factory hood pins, at least it calls out the hood pins. Why don't the early cars call the sport,raisin bran, rallye hood out ? There seems to be few early cars A66 showing up with wheel lip moldings are they all dealer installed ?
Re: A66 [Re: Beebuzzn] #562826
02/19/10 03:54 AM
02/19/10 03:54 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Obviously the "brass" wanted the Challenger to be all things to all people, and they were successful selling 83,000+ units in the first model year.
.... but late introduction of the "A66" package (what exactly was the package?) looks to have confused the line workers as much as it is confusing us.
I'm sure the early 340 Challengers caused all types of havoc on the assembly line.
The instructions for the "body-in-white" (fender tag) has JH "OOOPS" no R/T hood.
The "A66" cars were the first Challengers to be wheel-lip mouldingless, here comes a Challenger "OOOPS" it has wheel-lip mouldings now.
What's the next car in line its got a big white stripe, throw this black grill in it, "OOOPS"!
Re: A66 [Re: 6bblgt] #562827
02/19/10 02:17 PM
02/19/10 02:17 PM
Olympia WA
rocketresto Offline
rocketresto  Offline
Olympia WA
I think this is the best explination yet for the differences in the early A66 cars.
Mike
Re: A66 [Re: 6bblgt] #562828
02/19/10 02:26 PM
02/19/10 02:26 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
Very well said Dan!
Lots of people get all upset when we say things like A66 cars didn't get wheel lip moldings.
The retort ends up being "well when I bought mine new, it had them". It's irrelevant because the question wasn't talking about a single car. It was about a group of cars.
Could you order a 340 Challenger of any type with wheel lip moldings. The answer is no. Wheel lip molding aren't even on the order sheet since they were standard on all other Challengers.
Could one have been built with them, sure.
Same for grille surrounds. You could not specify the color, so nobody could order an A66 car with a black grille.
Re: A66 [Re: KISSAlien] #562829
02/19/10 03:29 PM
02/19/10 03:29 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I put some numbers together, these are ballpark - NOT exact!
~ 410,000 cars built for '70 at Hamtramck & Los Angeles
1 out of every 5 cars was a Challenger body
1 out of every 20 cars was a Challenger R/T (incl. R/T SE)
1 out of every 60 cars was a 340 Challenger
1 out of every 4 Challengers was a R/T (incl. R/T SE)
1 out of every 5 Challengers was FC7 "plum crazy"
1 out of every 12 Challengers was an "A66" 340 package car
1 out of every 2 cars was a DUSTER body
Re: A66 [Re: 6bblgt] #562830
02/19/10 03:44 PM
02/19/10 03:44 PM
Detroit, MI
DetMatt Offline
DetMatt  Offline
Detroit, MI
I am glad that I found mine, thank you craigslist!. Has anybody registered with Govier?, just curious.
`68 Road Runner "JUNKYARD DOG" `70 A66 FK5 Challenger, Rough project. `68 Coronet R/T Black & white 4 speed. `97 Dodge 1500 4X4, 228,000 miles and going strong!
Re: A66 [Re: DetMatt] #562831
02/19/10 04:56 PM
02/19/10 04:56 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
Mine is.
Re: A66 [Re: KISSAlien] #562832
02/19/10 05:11 PM
02/19/10 05:11 PM
Detroit, MI
DetMatt Offline
DetMatt  Offline
Detroit, MI
Did he tell you anything about it you didn't already know?.
