Re: A66 Challengers what color grille
[Re: KISSAlien]
#562633
12/30/09 03:16 PM
12/30/09 03:16 PM
Posts: 453 PNW
Beebuzzn
PNW
It could have been done when brand new though. If a customer wanted a sports hoos on a regular Challenger the dealer could have swapped them.
I could see someone going from flat hood to sport hood, but sport hood to flat hood ??? and then put holes in it for hood pins ? I just don't see that happening. I think the car being as original as it was tells the story. By the way I have the original hood and deck lid as I replaced both with the correct early 70 pieces do to some rust issues. Always keep my left overs just in case I need them for a reference. Maybe that's why I don't have any room in my garage.
[Re: Beebuzzn]
#562636
12/30/09 04:01 PM
12/30/09 04:01 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
Hamtramck - Historical is your friend. per the '70 Dodge "salesman's pocket guide" 9/23/69 version: CODE A66 - Challenger 340 CID engine package - $258.90 NA Special Edition (29), NA R/T (JS) 15" Rallye wheels (W21) - required at EXTRA costcollapsable spare (W34) - required at EXTRA costthis changed at some point - as the following shows per the '70 Dodge "dealership data book" no date foundCODE A66 - Challenger 340 CID engine package - includes 340 engine - E55 F70-14 RWL tires - T87 R/T hood H.D. brakes H.D. suspension "bumble bee" stripe "scat pack" decals wheel lip mouldings "DELETED" & we do need a picture of this 340 hood decal!!
[Re: 68Cbarge]
#562639
12/30/09 04:35 PM
12/30/09 04:35 PM
Posts: 4,321 St. Louis, Mo
318 Stroker
St. Louis, Mo
Weird thing is it has the foot-operated windshield washer pump.
Does it have rallye guages?
No,just the standard gauge cluster.
The reason I asked is that the electric washer came std. with the rallye guages.
On a std. cluster car, it is not weird at all to have the manual foot pump. As a matter of fact, most std. cluster cars came that way. The 3-spd. (or variable) wipers were optional with the std. cluster, and I don't think very many were ordered that way...
[Re: 6bblgt]
#562640
12/30/09 05:30 PM
12/30/09 05:30 PM
Posts: 11,022 Farmington, CT
KISSAlien
Farmington, CT
per the '70 Dodge "salesman's pocket guide" 9/23/69 version: CODE A66 - Challenger 340 CID engine package - $258.90 NA Special Edition (29), NA R/T (JS) 15" Rallye wheels (W21) - required at EXTRA cost collapsable spare (W34) - required at EXTRA cost
per the '70 Dodge "dealership data book" no date found CODE A66 - Challenger 340 CID engine package - includes 340 engine - E55 F70-14 RWL tires - T87 R/T hood H.D. brakes H.D. suspension "bumble bee" stripe "scat pack" decals wheel lip mouldings "DELETED"
7/23/69: The 340 Performance Package (A66) will be available on the hardtop and convertible models in conjunction with the 340 engine in early September. The 340 engine will only be available in combination with the 340 Performance Package.
10/20/69: Effective immediately, F70x14-inch RWL tires (T87) are standard with the 340 Performance Package. The E60x15-inch tires (U82) will be optional at extra cost. The Collapsible Spare (W34) and Rallye Wheels will no longer be required with the 340 Package. A Rear Spoiler in Dull Black (J81) will be available in early November. Effective immediately, Performance Axle Packages A31 and A36 are available with the 340 Package.
2/12/70: Longitudinal Tape Stripes on the Challenger high-Iine models (JH23, JH27, JH29) will be available in mid-March as an extra-cost option. Color availability and codes are: Black (V6X), White (V6W), Red (V6R), Green (V6F) and Blue (V6B). This tape stripe will be similar to the standard R/T stripe but without the R/T nomenclature. This stripe is a no-extra-cost option with the 340 Performance Package (A66).
4/13/70: The Shaker Hood is now available on the Challenger R/T with the 440-6V and 426 engines. In addition, this hood is also available with the 340 Performance Package (A66) and will be available on the 383 and 440-4V engines on R/T models in late April. The Challenger T/A Fiberglass Hood (N94) is now available on all Challenger models with 4-barrel engines.
[Re: 6bblgt]
#562641
12/30/09 05:36 PM
12/30/09 05:36 PM
KISSAlien
Farmington, CT
Who has an original broadcast sheet (or copy) for a '70 A66 Challenger?
I thought you had a copy of mine, but send me an email to remind me and I'll send you mine Dan.
Who has some documentaion that shows how the "package" was equipped at the start of the model year? Anything that shows E60-15s (U82) being STD etc.
[Re: Sublime70]
#562642
12/30/09 05:38 PM
12/30/09 05:38 PM
KISSAlien
Farmington, CT
Cool, it looks like the A66 cars only came in the coolest colors
Maybe we should start an A66 registry thread.
Not all of them. But because the bumble bee stripe was standard they did often get some of the rarer combinations. Here's mine.
+ Y05 26 EN1 + M21 N41 N42 R22 V21 V9W EW1 A66 C55 J45 J54 J81 EW1 H5X9 000 508 ****** E55 D13 JH12 H0B ******
[Re: KISSAlien]
#562643
12/30/09 06:12 PM
12/30/09 06:12 PM
6bblgt
Las Vegas, NV
I didn't know the "package wasn't available from the start of the model year. earliest VINs I have recorded are: "B" - MI - JH23H0B1158xx - SPD 90? "E" - LA - JH23H0E1096xx - SPD A03 Quote:
Effective immeadiately - DID THEY CUT THE PRICE by ~ $50? or add other features to the "package"?
YEAH Dodge!! 3 - R/Ts (2 are HEMI & 1 is 383) & 1 - A66 car KNOWN. I have a copy of the A66 car's b'cast sheet somewhere.
[Re: 69Mannix]
#562647
12/30/09 07:19 PM
12/30/09 07:19 PM
6bblgt
Las Vegas, NV
Late to the model line-up, sounds like Dodge got caught with their collective pants down by Plymouth, planning to offer the 'Cuda with the 340 as a no-cost option. This also would explain the decals on early cars as the lead time for an emblem would've been greater & they needed something fast. Is it 340 MAGNUM or 340 FOUR BARREL? I'd like to see pics of the top & bottom of "no-crush-zone" R/T hoods without holes for emblems. I'd like to see pics top & bottom of the clearance holes for hood pins on a "no-crush-zone" flat hood.
[Re: mccannix]
#562652
12/30/09 09:55 PM
12/30/09 09:55 PM
Beeware
Pic of the Hood Decal, I've owned this A66 car since 86 original paint car except hood, was a Hood Blackout car and was removed and repainted but they tapped off decals.
Hi Terry, Paul Petcou, from Michigan
