tremec 6-speed #562553
12/25/09 11:26 PM
12/25/09 11:26 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
i am curious about the tremec tk-6060 transmission that comes in many stock cars now (viper, vette, chally)
would a transmission like this be difficult to mate up to a big block mopar?
i really like the idea of 6 gears, and they seem to be a pretty readily available tranny at a reasonable price...
what all would be necessary other that getting a matching clutch set, and fabricating a crossmember, and mating up a driveshaft?
cost-wise, could i save some money going this route?
i definitely want a manual trans, but as a lot of others are, i am willing to do some fabrication to save some $$$....plus i like the idea of a short shift, and highway capability..
thanks for any input...
Re: tremec 6-speed [Re: Tommy383] #562554
12/25/09 11:27 PM
12/25/09 11:27 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
ill also be around 600 hp...i suspect it can handle that?
also forgot it needs a bellhousing to be found or made...
Post deleted by Defbob [Re: Tommy383] #562555
12/26/09 12:47 AM
12/26/09 12:47 AM
Re: tremec 6-speed #562556
12/26/09 01:16 AM
12/26/09 01:16 AM
Renton Washington
Triple Threat Offline
Renton Washington
How much does the CTS weigh Fred?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: tremec 6-speed #562557
12/26/09 01:33 AM
12/26/09 01:33 AM
Cab_Burge Online work
Cab_Burge  Online Work
there was one in my Caddy CTS V. was the operative word. it's apart on the bench .so far I can see two gears have no teeth on them.The Caddy is supercharged and about 700 hp
578 RWHP
You should never have installed that SS Hemi in that Caddy Fred just kidding
Re: tremec 6-speed [Re: Tommy383] #562558
12/26/09 02:08 AM
12/26/09 02:08 AM
AndyF Offline
AndyF  Offline
QuickTime has a bellhousing for a couple of different 6 speeds. I think they have a Viper bellhousing and one for the GM unit.
Re: tremec 6-speed [Re: AndyF] #562559
12/26/09 03:24 AM
12/26/09 03:24 AM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline
Give these guys a look, I think they will have the info you are looking for.
http://www.rsgear.com/transzilla.asp
Don
Street/Strip 73 Barracuda
Re: tremec 6-speed [Re: The Cuda Guy] #562560
12/26/09 04:24 AM
12/26/09 04:24 AM
QLD Australia
Keith Black® Offline
QLD Australia
I am in the middle of doing this. Have matched to my 572 Hemi.
The T6060 is the same as the T56 Magnum. Quicktime make a bellhousing P/N RM6077.
This trans is rated to 700/700, but investigation shows it will certainly handle more so I am prepared to take the risk as mine will not be seeing continuous load like that (just bursts)
Have LOADS of information & pic's, PM me.
Darren
Darren Beale
Keith Black Racing Engines®
Re: tremec 6-speed [Re: Keith Black®] #562561
12/26/09 03:27 PM
12/26/09 03:27 PM
Somewhere Over the Hill
Mr. Dodge Offline
Mr. Dodge  Offline
If your looking for a trans for your car look at http://www.americanpowertrain.com/ I have on going in a 1000 hp Hemi Coronet R/T and they guarantee it up to 1300 to 1400 ft lbs torque.
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison) 69 Hemi Coronet R/T 70 456 Dart Swinger
Re: tremec 6-speed [Re: Mr. Dodge] #562562
12/26/09 06:03 PM
12/26/09 06:03 PM
QLD Australia
QLD Australia
B Body install of T6060/T56Magnum:
Darren Beale
Re: tremec 6-speed [Re: Keith Black®] #562563
12/26/09 06:05 PM
12/26/09 06:05 PM
QLD Australia
QLD Australia
Bellhousing RM6077 (needed minor modification)
Use GM/Tremec T6060/T56 as input shaft length is correct.:
Darren Beale
Re: tremec 6-speed [Re: Keith Black®] #562564
12/26/09 06:16 PM
12/26/09 06:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Have any pics of the TB rear crossmember replacement yet?
Re: tremec 6-speed [Re: jcc] #562565
12/26/09 06:40 PM
12/26/09 06:40 PM
QLD Australia
QLD Australia
We're fabricating that right now.
Darren Beale
Re: tremec 6-speed [Re: Keith Black®] #562566
12/26/09 06:57 PM
12/26/09 06:57 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
so the gm input shaft doesnt need anything to be done...it is the correct size?
thanks for the pictures....looks like a nice ride!
Re: tremec 6-speed [Re: Tommy383] #562567
12/26/09 07:07 PM
12/26/09 07:07 PM
QLD Australia
QLD Australia
Yes, with the RM6077 bellhousing you have to use the Tremec TUET7277 (T56Magnum), or the other GM one (can't remember the PN), they have the correct input shaft length. With the bellhousing you need to use a 130th flywheel.
have just installed the Unlawful Racing 4-link rear too... (it's awesome.. will post another link on this).
Darren Beale
Re: tremec 6-speed [Re: Keith Black®] #562568
12/26/09 07:10 PM
12/26/09 07:10 PM
QLD Australia
QLD Australia
viewed from the back of the car..
Darren Beale
Re: tremec 6-speed [Re: Keith Black®] #562569
12/26/09 07:31 PM
12/26/09 07:31 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Looks like a pretty awesome car in the making Darren!
Re: tremec 6-speed [Re: Keith Black®] #562570
12/26/09 09:04 PM
12/26/09 09:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
No problem, actually the solution I'm looking for when you get to it will be the above the floorpan reinforcement solution you come up with.
Looks great
Re: tremec 6-speed [Re: jcc] #562571
12/26/09 11:14 PM
12/26/09 11:14 PM
MN
hemidup Offline
hemidup  Offline
MN
Heres something new for the RT56.
http://www.youtube.com/watch?v=OI2fGeL7DEE
Jerry Williams.
Re: tremec 6-speed [Re: hemidup] #562572
12/27/09 12:01 AM
12/27/09 12:01 AM
Renton Washington
Renton Washington
So the dodge trannys wont work due to the input length? The factory bellhousings should bolt right up to an A engine being the bolt pattern is the same as a new Hemi...
-Dustin
