Re: 4.375 in a 400 block
[Re: 602heavy]
#562195
12/26/09 01:05 PM
12/26/09 01:05 PM
Posts: 3,441 Mo.
supercomp
Mo.
FWIW , we've just freshened a 400"/545"....... 4.5 stroke , 4.437" bore , vanolia pistons , BME rods...............can't wait to see this thing run.
What pin height, rod lenght and did you have any piston to crank issues? The reason I'm asking is I don't have the parts yet and would like to know what to expect before I buy parts I can't use. Thanks
[Re: supercomp]
#562196
12/26/09 01:44 PM
12/26/09 01:44 PM
Posts: 1,200 UK
602heavy
UK
No problem , might take a few days to get hold of the spec sheets , can't remember off the top of my head.
[Re: 602heavy]
#562197
12/26/09 01:50 PM
12/26/09 01:50 PM
Posts: 3,441 Mo.
supercomp
Mo.
[Re: supercomp]
#562198
12/26/09 04:06 PM
12/26/09 04:06 PM
Posts: 16,928 NC
440Jim
NC
In a 400 block what are the chances of having piston to crank issues using a 4.375 K1 crank, 6.660 Compstar rods and Diamond 1.120 CH off the shelf pistons number 52008,
I think you can make it work with that rod length and stroke. If it gets close, you can remove some material from the crank counterweights before balancing. A diameter of 7.48" might be tight, but most low deck strokers can get by with 7.25" dia counterweights and that helps clear the block too. But I don't have any specific knowlage with that parts combination.
I think you know these are not buy the parts and throw them together type of things. It will take a mock-up (or 2) to check all sorts of things (rod bolts to cylinder bore bottom comes to mind, as well as the oil pickup boss, etc.)
[Re: supercomp]
#562199
12/26/09 05:15 PM
12/26/09 05:15 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
Will B1bs heads flowing 355 at .700 support a 526ci?
The best example of one on the board is Tom Sweden's B1bS 540 that dynoed at 800 hp.
[Re: B1Fish540]
#562200
12/26/09 05:27 PM
12/26/09 05:27 PM
Posts: 140 sweden
street_dart
sweden
I buy the heads from Tom (RT540).I have them on a 500" low deck now. More comp, better cam(Scott), more spring and lighter rotating = 841Hp@6400Rpm.
Dodge Dart-67
Dodge Custom Royal Lancer-55
Dodge Dakota 4.7 -05
[Re: supercomp]
#562202
12/27/09 10:17 AM
12/27/09 10:17 AM
Posts: 16,928 NC
440Jim
NC
I had to take .225 off our Callies 4.150 crank to balance it so they wouldn't have to swiss cheese it.
Similar with my Callies 4.250". Originally it was about 7.50" dia on the counterweights (with the 7.32" cam-cut at BDC). After going between the balancer and the lathe, it ended up at 7.14" dia. with a shallow drill for final balancing.
