Re: 440 Isky Adjustable Rockers
[Re: JohnnyBeGood]
#562079
12/25/09 03:10 AM
12/25/09 03:10 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
Just got a set of these and they are going to ras for an overhaul! What would be the best solid cam to use for street/strip set up? I will be using stock 915s or 906s mildly ported.
I'll bet(huh, Pete ) you that there will be several advocates for the Mopar "590 solid cam and lifter package" for your application. To get a good recommendation you need to list the rest of your package, car, weight, rear gear ratio, C.I., type of trans and if a automatic the size and stall of the converter, header size and exhaust pipe and type of mufflers, intake and carb size and so on
