4 barrel carb question for my 73 RR #562053
12/25/09 01:32 AM
12/25/09 01:32 AM
Pittsburgh, PA
bigdaddywiz Offline OP
Pittsburgh, PA
Hi guys. I've read from a few sources that back in the day guys were throwing 4 barrel carbs on their 318's that came with 2 bbl's on them from the factory to get a little performance boost. my 73 road runner is completly stock. i was going to just drop a bigger engine in, but didnt want to go through the trouble of changing the transmission and rear end out to handle the power.
would it be worth it to slap a 4 barrel on my car and would i notice enough power to make it any more fun? if so, is there a specific one that i would need that works with the 318 from 1973? also, what other mods could i do to that engine (without major tear down) to get more out of it? i'm not lookin to make it a fire breather. i know its just the 318. just want to make it a little more fun.
i've got a base model 73 road runner with the automatic.
thanks in advance!
73 Road Runner 09 Challenger R/T
Re: 4 barrel carb question for my 73 RR [Re: bigdaddywiz] #562054
12/25/09 07:31 AM
12/25/09 07:31 AM
Chesapeake, Va
4aThrill Offline
4aThrill  Offline
Chesapeake, Va
you can do alot to that 318 change the intake manifold, carb, headers, spark plugs, wires, rotor and cap hell you change the distributor for a better output of power if it hasn't already been done. what are you running for the rear and trans? 904? and what rear? theres alot you can do to make it run better and have more power. best thing to do is alot of research on whats good to use for the combo you want. Have fun and Happy Holidays
Re: 4 barrel carb question for my 73 RR [Re: 4aThrill] #562055
12/25/09 09:33 AM
12/25/09 09:33 AM
I'd suggest attacking the most restricted area of the eng 1st which would be adding some 340 HP ex manifolds (or headers if you can live with their issues) and a mandrel bent ex 2.5 or 3" that way if you upgrade the eng (& you will eventually) your ex will be adequate. A 600 eddie would be a good choice and I would for sure right now play w the dist curve/springs. You have a heav(ier) vehicle w a small eng and a deeper gear would make a world of difference in performance AND economy as the inertia of all that weight to get it moving is what hurts you. EDIT 73 was a bad year for emission mods and another 2bbl carb (75 or later) would help and if it's a carter the primary jets from an eddie strip kit will work in your 2bbl & benefit you
Re: 4 barrel carb question for my 73 RR [Re: RapidRobert] #562056
12/25/09 12:48 PM
12/25/09 12:48 PM
Pittsburgh, PA
Pittsburgh, PA
its got the 904 and the weaker rear end (from what a buddy who is a bit more knowledgable about that stuff than i am said). will i run into problems with either of those "weak links" with a little more power?
i'd like to just do bolt ons. what would have the biggest impact in that category?
merry christmas guys!
Re: 4 barrel carb question for my 73 RR [Re: bigdaddywiz] #562057
12/25/09 02:45 PM
12/25/09 02:45 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Exhaust is first i'd say
Then 4bbl...I like 600 holleys
Cam 3rd. You'll probably pick up more with the cam once you've done the other stuff than the others gave you.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: 4 barrel carb question for my 73 RR [Re: goldduster318] #562058
12/25/09 05:06 PM
12/25/09 05:06 PM
scratchnfotraction Offline
headers & duels first,best bang for the buck
stock 360 intake and q-jet/600 eddy with eddy LD4B,2nd biggest bang for the buck
swap in a stock /6 high stall torque converter,120$ reman from local tranz shop,3rd bigest bang for the buck
swap in a small Lunati voodoo cam with comp 901-16 springs 4th and biggest gain for the buck with the other bolt ons
get some 3.55 gears to get the full gain with all the bolt ons
do it all at once and you will need to find a rear axle upgrade/spare ASAP
may want to swap on some late model #302 closed chambered 318 heads to up the CR and be a little more efficent then add all the upgrades
it will be a nice little daily driver with some pep and fun back into it
Re: 4 barrel carb question for my 73 RR [Re: scratchnfotraction] #562059
12/25/09 05:34 PM
12/25/09 05:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would check out the rear gears first. If you have some granny gears in the rear diff, your 318 is going to be soggy no matter what bolt-ons you throw at it. First thing I would be spending money on is building a strong and aggressively geared rear diff. Then build a hi-po motor/trans on the side and swap them in when the time comes.
Re: 4 barrel carb question for my 73 RR [Re: DaytonaTurbo] #562060
12/25/09 07:27 PM
12/25/09 07:27 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: 4 barrel carb question for my 73 RR [Re: bigdaddywiz] #562061
12/26/09 01:06 AM
12/26/09 01:06 AM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
did your buddy actually crawl under the car and verify it, or just assume that a 318 car had a "weak" rearend?
fyi, my old 74 was a factory 318 car, and had a 8 3/4 with it...
Re: 4 barrel carb question for my 73 RR [Re: James74] #562062
12/26/09 10:13 AM
12/26/09 10:13 AM
Pittsburgh, PA
Pittsburgh, PA
what would the "weaker" rear end be for my year?
Re: 4 barrel carb question for my 73 RR [Re: bigdaddywiz] #562063
12/26/09 10:19 AM
12/26/09 10:19 AM
Great White North
W
Wheeler Offline
Wheeler  Offline
W
Great White North
If you are not worried about keeping the car 100% original, I strongly recommend the 4bbl intake and carb swap. The 4bbl carb will be a huge improvement in performance and driveability.
For the carb, I would get either a spreadbore carb or a squarebore carb in the 500-600 cfm range. Here are some suggestions:
- Spreadbore carb: Rebuilt Rochester Quadrajet, new Holley Spreadbore
- Squarebore carb: Holley Street Avenger 570 cfm, Barry Grant Road Demon 525 cfm, Edelbrock 500 cfm, rebuilt Carter AFB 500 cfm.
For spreadbores, I personally like the Rochester Q-Jet. IMO, the Q-Jet is more reliable and less tempermental than the Carter Thermoquad. I would consider a Q-Jet ONLY if you can get one from a quality carb rebuilder that specializes in them (stay away from the rebuilt carbs you can buy at your local auto parts store). Otherwise, you should spend the extra bucks for a new carb.
If you are looking for a brand new carb, I like the Holley Street Avenger or BG Road Demon (providing the quality control on the BG carb is good). The Edelbrock 500 cfm would be a decent choice as well but Edelbrock carbs tend to have a heat percolation problem that can cause hard starting problems.
BTW - What happened to the old Carter AFB 500 cfm carbs you could buy at the auto parts stores?
For the intake manifold, it depends in what style of carb you want to use (spreadbore or squarebore) and how much money you want to spend. I like the following intakes:
- Factory 340 or 360 cast iron intake. Ideal if you are budget conscious and wanted to keep a stock look. 1968-1970 340 intakes have a squarebore pattern. 1973-up 340 and 360 4bbl intakes have the spreadbore pattern.
- Edelbrock LD4B (if you can find a used one in good condition). GREAT intake for a 318. Has the squarebore pattern.
- Edelbrock Performer: Will accept spreadbore and squarebore carbs. Performance wise - not really an improvement over a stock 340/360 intake. The Edelbrock LD4B and LD340 intakes are a lot better performancewise.
- Mopar M1
FYI - The factory 340/360 intake and most aluminum intakes for the small block Mopar have larger ports than a 318 intake. The port mismatch is nothing to worry about - just make sure you use high quality intake manifold gaskets. The only intakes (I am aware of) that have the smaller 318 sized ports are the Edelbrock LD4B and Edelbrock Performer intakes.
Hope this helps - good luck!
Re: 4 barrel carb question for my 73 RR [Re: bigdaddywiz] #562064
12/26/09 10:43 AM
12/26/09 10:43 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
8-1/4" rearend, just look for a 10 bolt cover on the back of the housing. It will be plenty strong for what you're going to do to the motor.
The 8-3/4" doesn't have a cover as it has a removeable center section.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: 4 barrel carb question for my 73 RR [Re: Wheeler] #562065
12/26/09 10:43 AM
12/26/09 10:43 AM
could have an 8 3/4 rear axle,take a look at it,from the back it will have a round non-removable cover
I usally get a mid 70s chebby q-jet and tac weld the mopar throttle arm to it and run them that way to get a good non emissions carb that works well...327 and 318 are close for jetting
last reman one I got from autozone was in the 120$ range and still working fine
Re: 4 barrel carb question for my 73 RR [Re: bigdaddywiz] #562066
12/26/09 10:46 AM
12/26/09 10:46 AM
7&1/4 (it has a 9 bolt side cover).
Re: 4 barrel carb question for my 73 RR [Re: MY340] #562067
12/26/09 10:51 AM
12/26/09 10:51 AM
Pittsburgh, PA
Pittsburgh, PA
ok, thanks...that answers my question. mines got a rear cover on it, so its the 8-1/4" rear.
Re: 4 barrel carb question for my 73 RR [Re: Wheeler] #562068
12/26/09 10:55 AM
12/26/09 10:55 AM
Pittsburgh, PA
Pittsburgh, PA
For the carb, I would get a
- Spreadbore carb: Rebuilt Rochester Quadrajet or new Holley Spreadbore
- Squarebore carb in the 500-600 cfm range: Holley Street Avenger 570 cfm, Barry Grant Road Demon 525 cfm or Edelbrock 500 cfm
For the intake manifold, it depends in what style of carb you want to use (spreadbore or squarebore): I like the following intakes:
thank you so much wheeler and everyone else whos tryin to help this slightly un-educated guy get what i need!
Re: 4 barrel carb question for my 73 RR [Re: bigdaddywiz] #562069
12/26/09 10:59 AM
12/26/09 10:59 AM
Great White North
W
Wheeler Offline
Wheeler  Offline
W
Great White North
You're welcome, glad to help! Please refer to my post again - I made some changes and added more info.
Re: 4 barrel carb question for my 73 RR [Re: bigdaddywiz] #562070
12/26/09 06:17 PM
12/26/09 06:17 PM
Sandy, OR
DART67GT Offline
DART67GT  Offline
Sandy, OR
Those 8 1/4 rears aren't all that weak. I have a 318 w/360 j heads, holley double pumper, headers w/dual exhaust and a 904. I put a lot of miles on that back in high school. Many burnouts and never broke it. Sure the 8 3/4 is better, but not necessary behind a mild small block.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
Re: 4 barrel carb question for my 73 RR [Re: bigdaddywiz] #562071
12/26/09 06:36 PM
12/26/09 06:36 PM
douglasville,ga
ramrod Offline
ramrod  Offline
douglasville,ga
My first car was a 318 2-bbl '73 Road Runner. It wouldn't pull past 3500 RPM stock....
I got some 360 heads, had the intake valve seats cut for 2.02" 340 intake valves and had the heads milled .060" to get the compression up. Used stock 340 valvesprings and an early 340 square bore iron intake. Added a 650 DP carb and the smallest hydraulic cam from PAW. Threw on a pair of Blackjack Alumicoat headers and some header mounted glasspacks (hey, I was 15 years old!). Really woke the little 318 up. It would rev past 6K and spin the 3.23 peg leg as far as you wanted. I never broke the 8.25 rear, but after about 5 years and some trips to the track it was getting kinda sloppy.
"That Plymouth had a Hemi with a Torqueflite." -Driver
Re: 4 barrel carb question for my 73 RR [Re: ramrod] #562072
12/26/09 11:10 PM
12/26/09 11:10 PM
Manitoba, Canada
Manitoba, Canada
Even if you have a 8.25 rear, it still pays to jack up the back of the car and figure out what your rear gear ratio is. If you've got some 2.76 granny gears or similar, that 318 will still be a dog even with a 4bbl, heads, cam, headers, etc. You may need to evaluate whether it's worth doing $ motor mods or upgrading rear diff or even just upgrading your 8.25's rear end ratio.
