4 barrel carb question for my 73 RR
#562053
12/25/09 01:32 AM
12/25/09 01:32 AM
Posts: 124 Pittsburgh, PA
bigdaddywiz
Pittsburgh, PA
Hi guys. I've read from a few sources that back in the day guys were throwing 4 barrel carbs on their 318's that came with 2 bbl's on them from the factory to get a little performance boost. my 73 road runner is completly stock. i was going to just drop a bigger engine in, but didnt want to go through the trouble of changing the transmission and rear end out to handle the power.
would it be worth it to slap a 4 barrel on my car and would i notice enough power to make it any more fun? if so, is there a specific one that i would need that works with the 318 from 1973? also, what other mods could i do to that engine (without major tear down) to get more out of it? i'm not lookin to make it a fire breather. i know its just the 318. just want to make it a little more fun.
i've got a base model 73 road runner with the automatic.
thanks in advance!
73 Road Runner
09 Challenger R/T
Re: 4 barrel carb question for my 73 RR
[Re: 4aThrill]
#562055
12/25/09 09:33 AM
12/25/09 09:33 AM
RapidRobert
I'd suggest attacking the most restricted area of the eng 1st which would be adding some 340 HP ex manifolds (or headers if you can live with their issues) and a mandrel bent ex 2.5 or 3" that way if you upgrade the eng (& you will eventually) your ex will be adequate. A 600 eddie would be a good choice and I would for sure right now play w the dist curve/springs. You have a heav(ier) vehicle w a small eng and a deeper gear would make a world of difference in performance AND economy as the inertia of all that weight to get it moving is what hurts you. EDIT 73 was a bad year for emission mods and another 2bbl carb (75 or later) would help and if it's a carter the primary jets from an eddie strip kit will work in your 2bbl & benefit you
[Re: RapidRobert]
#562056
12/25/09 12:48 PM
12/25/09 12:48 PM
bigdaddywiz
Pittsburgh, PA
its got the 904 and the weaker rear end (from what a buddy who is a bit more knowledgable about that stuff than i am said). will i run into problems with either of those "weak links" with a little more power?
i'd like to just do bolt ons. what would have the biggest impact in that category?
merry christmas guys!
73 Road Runner
09 Challenger R/T
[Re: bigdaddywiz]
#562057
12/25/09 02:45 PM
12/25/09 02:45 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Exhaust is first i'd say Then 4bbl...I like 600 holleys Cam 3rd. You'll probably pick up more with the cam once you've done the other stuff than the others gave you.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#562058
12/25/09 05:06 PM
12/25/09 05:06 PM
Posts: 15,487 Florida
scratchnfotraction
headers & duels first,best bang for the buck stock 360 intake and q-jet/600 eddy with eddy LD4B,2nd biggest bang for the buck swap in a stock /6 high stall torque converter,120$ reman from local tranz shop,3rd bigest bang for the buck swap in a small Lunati voodoo cam with comp 901-16 springs 4th and biggest gain for the buck with the other bolt ons get some 3.55 gears to get the full gain with all the bolt ons do it all at once and you will need to find a rear axle upgrade/spare ASAP may want to swap on some late model #302 closed chambered 318 heads to up the CR and be a little more efficent then add all the upgrades it will be a nice little daily driver with some pep and fun back into it
[Re: DaytonaTurbo]
#562060
12/25/09 07:27 PM
12/25/09 07:27 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
I would check out the rear gears first. If you have some granny gears in the rear diff, your 318 is going to be soggy no matter what bolt-ons you throw at it. First thing I would be spending money on is building a strong and aggressively geared rear diff. Then build a hi-po motor/trans on the side and swap them in when the time comes.
[Re: bigdaddywiz]
#562061
12/26/09 01:06 AM
12/26/09 01:06 AM
Posts: 1,771 Jamestown, Indiana
James74
Jamestown, Indiana
did your buddy actually crawl under the car and verify it, or just assume that a 318 car had a "weak" rearend?
fyi, my old 74 was a factory 318 car, and had a 8 3/4 with it...
[Re: James74]
#562062
12/26/09 10:13 AM
12/26/09 10:13 AM
bigdaddywiz
Pittsburgh, PA
what would the "weaker" rear end be for my year?
73 Road Runner
09 Challenger R/T
[Re: bigdaddywiz]
#562063
12/26/09 10:19 AM
12/26/09 10:19 AM
Posts: 3,318 Great White North
Wheeler
Great White North
If you are not worried about keeping the car 100% original, I strongly recommend the 4bbl intake and carb swap. The 4bbl carb will be a huge improvement in performance and driveability.
For the carb, I would get either a spreadbore carb or a squarebore carb in the 500-600 cfm range. Here are some suggestions:
- Spreadbore carb: Rebuilt Rochester Quadrajet, new Holley Spreadbore
- Squarebore carb: Holley Street Avenger 570 cfm, Barry Grant Road Demon 525 cfm, Edelbrock 500 cfm, rebuilt Carter AFB 500 cfm.
For spreadbores, I personally like the Rochester Q-Jet. IMO, the Q-Jet is more reliable and less tempermental than the Carter Thermoquad. I would consider a Q-Jet ONLY if you can get one from a quality carb rebuilder that specializes in them (stay away from the rebuilt carbs you can buy at your local auto parts store). Otherwise, you should spend the extra bucks for a new carb.
If you are looking for a brand new carb, I like the Holley Street Avenger or BG Road Demon (providing the quality control on the BG carb is good). The Edelbrock 500 cfm would be a decent choice as well but Edelbrock carbs tend to have a heat percolation problem that can cause hard starting problems.
BTW - What happened to the old Carter AFB 500 cfm carbs you could buy at the auto parts stores?
For the intake manifold, it depends in what style of carb you want to use (spreadbore or squarebore) and how much money you want to spend. I like the following intakes: - Factory 340 or 360 cast iron intake. Ideal if you are budget conscious and wanted to keep a stock look. 1968-1970 340 intakes have a squarebore pattern. 1973-up 340 and 360 4bbl intakes have the spreadbore pattern. - Edelbrock LD4B (if you can find a used one in good condition). GREAT intake for a 318. Has the squarebore pattern. - Edelbrock Performer: Will accept spreadbore and squarebore carbs. Performance wise - not really an improvement over a stock 340/360 intake. The Edelbrock LD4B and LD340 intakes are a lot better performancewise. - Mopar M1
FYI - The factory 340/360 intake and most aluminum intakes for the small block Mopar have larger ports than a 318 intake. The port mismatch is nothing to worry about - just make sure you use high quality intake manifold gaskets. The only intakes (I am aware of) that have the smaller 318 sized ports are the Edelbrock LD4B and Edelbrock Performer intakes.
Hope this helps - good luck!
[Re: MY340]
#562067
12/26/09 10:51 AM
12/26/09 10:51 AM
bigdaddywiz
Pittsburgh, PA
8-1/4" rearend, just look for a 10 bolt cover on the back of the housing. It will be plenty strong for what you're going to do to the motor.
The 8-3/4" doesn't have a cover as it has a removeable center section.
ok, thanks...that answers my question. mines got a rear cover on it, so its the 8-1/4" rear.
73 Road Runner
09 Challenger R/T
[Re: Wheeler]
#562068
12/26/09 10:55 AM
12/26/09 10:55 AM
bigdaddywiz
Pittsburgh, PA
For the carb, I would get a - Spreadbore carb: Rebuilt Rochester Quadrajet or new Holley Spreadbore - Squarebore carb in the 500-600 cfm range: Holley Street Avenger 570 cfm, Barry Grant Road Demon 525 cfm or Edelbrock 500 cfm
For the intake manifold, it depends in what style of carb you want to use (spreadbore or squarebore): I like the following intakes: - Factory 340 or 360 cast iron intake. Ideal if you are budget conscious and wanted to keep a stock look. 1968-1970 340 intakes have a squarebore pattern. 1973-up 340 and 360 4bbl intakes have the spreadbore pattern. - Edelbrock LD4B (if you can find a used one in good condition). GREAT intake for a 318. Has the squarebore pattern. - Edelbrock Performer: Will accept spreadbore and squarebore carbs. Performance wise - not really an improvement over a stock 340/360 intake. The Edelbrock LD4B and LD340 intakes are a lot better performancewise.
thank you so much wheeler and everyone else whos tryin to help this slightly un-educated guy get what i need!
73 Road Runner
09 Challenger R/T
[Re: bigdaddywiz]
#562069
12/26/09 10:59 AM
12/26/09 10:59 AM
Wheeler
Great White North
You're welcome, glad to help! Please refer to my post again - I made some changes and added more info.
[Re: bigdaddywiz]
#562070
12/26/09 06:17 PM
12/26/09 06:17 PM
Posts: 1,010 Sandy, OR
DART67GT
Sandy, OR
Those 8 1/4 rears aren't all that weak. I have a 318 w/360 j heads, holley double pumper, headers w/dual exhaust and a 904. I put a lot of miles on that back in high school. Many burnouts and never broke it. Sure the 8 3/4 is better, but not necessary behind a mild small block.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads
2000 Dodge Ram 2500 Quad Cab CTD
[Re: bigdaddywiz]
#562071
12/26/09 06:36 PM
12/26/09 06:36 PM
Posts: 199 douglasville,ga
ramrod
douglasville,ga
My first car was a 318 2-bbl '73 Road Runner. It wouldn't pull past 3500 RPM stock.... I got some 360 heads, had the intake valve seats cut for 2.02" 340 intake valves and had the heads milled .060" to get the compression up. Used stock 340 valvesprings and an early 340 square bore iron intake. Added a 650 DP carb and the smallest hydraulic cam from PAW. Threw on a pair of Blackjack Alumicoat headers and some header mounted glasspacks (hey, I was 15 years old!). Really woke the little 318 up. It would rev past 6K and spin the 3.23 peg leg as far as you wanted. I never broke the 8.25 rear, but after about 5 years and some trips to the track it was getting kinda sloppy.
"That Plymouth had a Hemi with a Torqueflite."
-Driver
[Re: ramrod]
#562072
12/26/09 11:10 PM
12/26/09 11:10 PM
DaytonaTurbo
Manitoba, Canada
Even if you have a 8.25 rear, it still pays to jack up the back of the car and figure out what your rear gear ratio is. If you've got some 2.76 granny gears or similar, that 318 will still be a dog even with a 4bbl, heads, cam, headers, etc. You may need to evaluate whether it's worth doing $ motor mods or upgrading rear diff or even just upgrading your 8.25's rear end ratio.
[Re: DaytonaTurbo]
#562073
12/27/09 10:32 AM
12/27/09 10:32 AM
scratchnfotraction
pull the cover and change the oil on the rear axle when you have it off,the gear ratio is stamped in the edge of the ring gear along with the date no guessing that way 2.76 may be slow out the hole but it will fly on the highway IMO,add HP to those gears and they will go fast...300mph dragsters use a 2.76 gear with 1400HP
[Re: scratchnfotraction]
#562074
12/27/09 08:36 PM
12/27/09 08:36 PM
bigdaddywiz
Pittsburgh, PA
so if i was just to go the 4bbl intake setup and other easy bolt ons, how much of an estimated gain will i be looking at?
73 Road Runner
09 Challenger R/T
[Re: bigdaddywiz]
#562076
12/27/09 09:19 PM
12/27/09 09:19 PM
DaytonaTurbo
Manitoba, Canada
Depends on what you consider to be easy bolt-ons. By that do you mean just intake, carb and headers? Going into the engine to do cam and valve springs is a bit more work. If you were going to go that far I would suggest a magnum head swap. If you're just doing the simple stuff like intake/carb/headers, I would expect maybe a 20-30hp and torq increase. Stock cam and heads will kill performance.
