67 Dart sill plate screws #561668
12/24/09 02:37 PM
12/24/09 02:37 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Does anyone happen to know what kind/size screw is used for the door sill plates on a 67 Dart? I tried a few screws already installed on the interior, but can't find a match for the size..
Re: 67 Dart sill plate screws [Re: Exit1965] #561669
12/24/09 11:49 PM
12/24/09 11:49 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
They are a special screw about 1/2" long with s semi-round head and a flat spot where the phillips cross is. I believe R/T Specialties has them.
JB Rhinehart, Realist
A-Body's RULE!
Re: 67 Dart sill plate screws [Re: Rhinodart] #561670
12/25/09 05:02 PM
12/25/09 05:02 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Thank you sir, I'll check with them. Merry Christmas.
Re: 67 Dart sill plate screws [Re: Exit1965] #561671
12/25/09 10:55 PM
12/25/09 10:55 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Re: 67 Dart sill plate screws [Re: Exit1965] #561672
12/26/09 06:21 PM
12/26/09 06:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
They're call a truss head screw. #8 and chrome plated
Re: 67 Dart sill plate screws [Re: gtx6970] #561673
12/26/09 08:03 PM
12/26/09 08:03 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Thanks guys, I actually picked some up at Lowes -- not the correct kind, but a #8 x 1/2" which did the trick.
