mopar cam 557?
#561085
12/23/09 08:50 PM
12/23/09 08:50 PM
Posts: 526 orange,tx
onebadstepside
orange,tx
Whats the scoop on the mopar cam 296...557?What are ya shifting at?Combos and ET's are welcome...I know there are better cams out there,just wondering if its still a decent choice for a low buck 360
Small blocks rule!!!!!
Re: mopar cam 557?
[Re: onebadstepside]
#561089
12/23/09 09:18 PM
12/23/09 09:18 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Thats a fantastic budget camshaft! We used it in my brothers first small block. It shifted at 7200rpm with a 3.79 stroke. It also had box stock edelbrock cylinder heads and an M1 manifold. The car went 11.09 @ 118mph with that cam. With a 3.58 stock stroke 360 it should be more like 7400-7500 RPM with the similar parts used. It sounded great as well. Im not sure how well it would work in a heavy vehicle though.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
Re: mopar cam 557?
[Re: PUNK]
#561090
12/23/09 09:29 PM
12/23/09 09:29 PM
Posts: 5,620 long island NY
Ari440
long island NY
what compression would be mininum for the 557 cam ?
10.1 good ?
1.39 9.85 - 137 mph
Re: mopar cam 557?
[Re: S/ST 3040]
#561092
12/23/09 09:49 PM
12/23/09 09:49 PM
onebadstepside
orange,tx
Sounds like this cam is actually bigger than the advertised numbers.What makes cam pull so high in the rpm?
Re: mopar cam 557?
[Re: S/ST 3040]
#561093
12/23/09 09:52 PM
12/23/09 09:52 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
In the MP book they say to use .850 x advertized duration to find approximate .050 numbers for cams in the mild range. It works pretty good for the most part up to the MP .590 cam For me the MP cams below matched the .850 math .484 @ 284 = 241 @ .050 .509 @ 292 = 248 @ .050 .557 @ 296 = 251 @ .050 and actually measured the same or very close. But the MP .590 didnt .590 @ 312 = 265.2 @ .050, it actually measured 272 @ .050 Reguardless, I like the All the MP cams above, the MP .557 is a good one. My measurements above were on the BB cams only. I assume, the SB lobe profiles would be the same. mike
Re: mopar cam 557?
[Re: DaKuda]
#561096
12/23/09 11:43 PM
12/23/09 11:43 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Used it in a low compression 440 and went 11.30's.Still have the cam and will use it again in a new engine.Shifted at 6500.
Re: mopar cam 557?
[Re: Ari440]
#561098
12/24/09 12:17 AM
12/24/09 12:17 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
for a small block ,do you happen to know what this cam is at *50 ?
The one I put in a 360 a couple years ago measured 255 @.050. The car was shifted @ 6000 and went through @6200.Went a best of 11.78 in a 3400 pound street car.360 with ootb Edelbrocks. The best street/strip small block cam I have personally ever used.
Re: mopar cam 557?
[Re: Dunnuck Racing]
#561099
12/24/09 12:26 AM
12/24/09 12:26 AM
Ari440
long island NY
I will be putting a 340 together for a freind
10.1 comp , 540/235 (not sure), J head 2.02 m1 750carb
would the 557 be a good upgrade for this 340
its on a budget / low key combo
557 with 1.6 ratio rockers ,whats the lift ?
1.39 9.85 - 137 mph
Re: mopar cam 557?
[Re: PUNK]
#561100
12/24/09 12:28 AM
12/24/09 12:28 AM
Posts: 799 north west LA
W2DODGE
north west LA
thats a bunch more RPM than that cam likes
my 69 dart 2970 lbs W-2 318 only turned 6,700 RPM to run 10.9s @ 121 the same cam in my 360 liked about 6,600 RPM ran 6.6s @ 104 1/8th its a nice cam makes good power for what it is and is verey mild manered if you want to run it on the street
Re: mopar cam 557?
[Re: Ari440]
#561103
12/24/09 12:47 AM
12/24/09 12:47 AM
Dunnuck Racing
Northern Indiana
If you already have it,I would definately use it. Mine was 10.3 to one,for what it's worth.
