Re: Mig Welders which one?
[Re: flatiron]
#560301
12/22/09 10:55 PM
12/22/09 10:55 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I just got a Hobart 140 mig for 476.10 shipped off e-bay (sgweldstore), it works great. came with a 3 yr. warr.
[Re: flatiron]
#560302
12/22/09 10:59 PM
12/22/09 10:59 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Although I'd recommend you use gas, you can buy a conversion kit, remember to reverse the polarity settings in a gasless machine when converting to gas use,....I highly recommend the Hobart as the transformer, wire drive, handle will be Miller items, easily repaired or replaced,although unlikley to fail, plus the wiredrive is far superior to the Lincoln wiredrive, which is a POS IMHO Mike
[Re: flatiron]
#560303
12/22/09 11:19 PM
12/22/09 11:19 PM
Posts: 7,506 Az
Crizila
Az
HTP 140 - and don't bother going gasless. You won't like the welds.
Fastest 300
[Re: Stanton]
#560306
12/23/09 12:42 AM
12/23/09 12:42 AM
joedust451
super gas
super gas
Branson, Mo.
Didn't this get beat to death a week ago ?!?!?!?!?
I think it did, i do know i had started a thread not to long ago, but a week on Moparts Q&A is long gone or a good 18-20 pages away, maybe more, i think a "sticky" would be a good thing, or a "welding" section.
[Re: joedust451]
#560307
12/23/09 02:02 AM
12/23/09 02:02 AM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
It did in deed get discussed at nauseum. That being said, one consensus was that if you EVER consider doing anything heavier than body or exhaust work, you'll regret the 115/120 volt units. Even if ALL you do is body work, if you do a lot, plan on a gouge in your electric budget. I don't understand all I know about electricity, but I do know the 220 volt units are much cheaper to run. Also, as was stated previously, if you go strictly gas-less, you won't be happy. I have a gas-less 110 Lincoln and a gassed 220 Hobart. I tried using the Lincoln on body repairs because I had to work outside and didn't want to deal with the headaches of breezes and gas shield. The flux core wire, even at the lower voltage heats the metal too much and distortion was hard to control, not to mention the slag and excess splatter. I finally got fed up and scrounged a large piece of cardboard for a wind break and drug out the Hobart. I was a much happier camper.
[Re: flatiron]
#560308
12/23/09 06:10 AM
12/23/09 06:10 AM
Posts: 22,696 Bitopia
jcc
Bitopia
This is not the end all, be all recent welding thread, but its a start: https://board.moparts.org/ubbthreads/show...rue#Post5636933
[Re: Stanton]
#560310
12/23/09 08:23 AM
12/23/09 08:23 AM
Posts: 724 PA USA
flatiron
PA USA
Sorry for the question but I have been without a computer for alittle over 2 weeks
[Re: flatiron]
#560311
12/23/09 10:37 AM
12/23/09 10:37 AM
Posts: 18,157 Mass
DAYCLONA
Mass
It's like any other posts on Moparts, what classic car insurance to use, my car won't start, how to bleed brakes, who makes the cheapest....., how do I paint mt car with a brush and roller,...now thats one dead horse that rears it ugly head all the time ......some people are new, or never explored that facet of the hobby until they need to, don't know why people get their undies in bunchies over a simple question, even if they've seen it a hundred times
[Re: DAYCLONA]
#560315
12/23/09 01:52 PM
12/23/09 01:52 PM
Posts: 724 PA USA
flatiron
PA USA
Thank you I have been really thinking about signing off due to some of the know it all members on here. Some of use have only been at it for a short while and we have questions. I belive thats what forums are designed for. But I do think maybe a tool section would be very helpful.
[Re: DoctorDiff]
#560317
12/23/09 02:17 PM
12/23/09 02:17 PM
Posts: 4,978 VA
DAMOPARS
VA
The solution is pretty simple. If you dislike duplicate questions, do not read and do not post on the thread.
Well said Cass
Hobart or Miller
[Re: maximus]
#560319
12/23/09 02:31 PM
12/23/09 02:31 PM
Posts: 724 PA USA
flatiron
PA USA
I have a Century and use it quite often. It has never failed me. When I bought it 15 years ago the salesman (who I trust) of a large welding supply company said it was better because it has copper windings instead of aluminum. The duty time is a lot longer than the others at the time. Compare the duty cycle of each you are looking at, I know things have changed over the years since I bought mine. The good thing about aluminum windings it's lighter, mine is heavy.
Could someone explain Duty cycle and what it means
