Valve Diameter, Throat Area, Port Area? #559976
12/22/09 02:04 PM
12/22/09 02:04 PM
Thigh-Gap Junction
@#$%&*! Offline OP
New user name, Same old jerk!
@#$%&*!  Offline OP
Thigh-Gap Junction
Just wondering if there are any rules-of-thumb or general guidelines on the relationship between the valve diameter, throat area below the valve, and the minimum area of the port tract.
Thanks in advance and happy holidays.
Re: Valve Diameter, Throat Area, Port Area? [Re: @#$%&*!] #559977
12/22/09 02:54 PM
12/22/09 02:54 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
This subject can be discussed endlessly,but the most important is a smooth transition from the valve pocket to the port runner and gain as much area and the lest obstruction as possible without weakening or damage the head.
Re: Valve Diameter, Throat Area, Port Area? [Re: @#$%&*!] #559978
12/22/09 04:14 PM
12/22/09 04:14 PM
detroit area
moderncylinder Offline
detroit area
yes,,, there are
Re: Valve Diameter, Throat Area, Port Area? [Re: @#$%&*!] #559979
12/22/09 04:38 PM
12/22/09 04:38 PM
sg66mopar Offline
sg66mopar  Offline
Hey Cory
Does this mean we're going faster next year?
Re: Valve Diameter, Throat Area, Port Area? [Re: @#$%&*!] #559980
12/22/09 04:40 PM
12/22/09 04:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You need to ask this on SpeedTalk.com; Moparts isn't technical enough anymore to answer this kind of question...
Re: Valve Diameter, Throat Area, Port Area? [Re: BradH] #559981
12/22/09 04:57 PM
12/22/09 04:57 PM
detroit area
detroit area
i did answer his question,, all he asked was if there were general rules for a few parameters,,, he didnt ask what they were..
Re: Valve Diameter, Throat Area, Port Area? [Re: moderncylinder] #559982
12/22/09 05:10 PM
12/22/09 05:10 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
From memory it was around 90-93%
Hopefully Jeff corrects me if I am wrong.
As mentioned, Speedtalk is an excellent forum for these kind of questions, do a search there before you ask.
AL....
Alan Jones
Re: Valve Diameter, Throat Area, Port Area? [Re: B G Racing] #559983
12/22/09 05:50 PM
12/22/09 05:50 PM
Thigh-Gap Junction
@#$%&*! Offline OP
@#$%&*!  Offline OP
Thigh-Gap Junction
Well, I wouldn't want to start an endless discussion, and certainly not a debate.
[yes,,, there are
The thanks-in-advance weren't meant to be sarcasm in advance... Merry to you.
Hey Cory, Does this mean we're going faster next year?
I know you are. This is about another engine/car entirely. If I get that roller cam for xmas then yes, WE are going to be faster. Still, I don't plan to run under 10 any time soon, unless it's to PO a track manager or something.
Join another forum, no thanks. If moparts fails me I'll just come up with my own ideas. That's my usual way of solving problems anyway. Anyone who's seem my sh1t knows that.
The reason I'm asking is that I have some heads I've been working on that are 1.84/1.56 in the valve size area and I'm changing them to 2.0/1.6 and just want to size the port and throat correctly, or close anyway. Min area in the port is now about 1.8in^2 and the Wallace calculator I tried said max torque at about 4100 rpm, fwiw. There's room to make the port bigger.
Re: Valve Diameter, Throat Area, Port Area? [Re: LA360] #559984
12/22/09 06:54 PM
12/22/09 06:54 PM
detroit area
detroit area
it really depends on chamber style, valve job angles, valve back profile, port floor height, and operating range with a respect to cros ssection and displacemnt.
usually 92% on the intake and 89% on the exh,, with 45 degree seats and atleast a 30 degree top ngle thats .060 or so wide,, nothing flatter for a top or else you make the throat smaller. if its a flat machined chamber you make the throat smaller, if its a 30 degree seat you make the throat smaller,,, if its a 55-58 seat you make the throat larger..
also depends on seat width,, if its a true sreet car you run wider seats to help dissipate heat off the valve head,, so then you make the throat smaller,, if seat widths are .050 or wider, the above 92% intake is for a .035 or so wide seat, exh .045
if you take alot of factory heads and goto oversize valves you can get into trouble going 92% cause the casting wont support it, the bowl cant be made large enough.......
