Comp Cams Pro Magnum 440 Steel Rockers ??
#559763
12/22/09 03:01 AM
12/22/09 03:01 AM
Posts: 100 Wisconsin USA
Albert Lee
Wisconsin USA
Has anyone used the subject rockers on a 500 Hp drag race 440 with a .590" lift, solid lifter cam. This is in a 11 second B body with 440 Source heads and a 727 automatic.
Thanks in advance for your comments!
Re: Comp Cams Pro Magnum 440 Steel Rockers ??
[Re: tboomer]
#559765
12/22/09 03:22 AM
12/22/09 03:22 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
I believe the rockers are only rated for 350 LB or less open spring pressures.
Leave the gun.......take the Cannoli's....Mike
[Re: Albert Lee]
#559767
12/22/09 12:10 PM
12/22/09 12:10 PM
Posts: 5,080 organ
maximum entropy
organ
iirc comp say they are good to ~ 400 pounds. they can be bushed to increase load capacity, as the problem with them at high pressure has been galling of the shaft.
[Re: maximum entropy]
#559768
12/22/09 01:03 PM
12/22/09 01:03 PM
Posts: 289 Lowes
steve660
Lowes
Ive ran a set for 4 years and about 5000 miles with at least 400 passes with them. There not "recommended" for spring pressure over 350 ish, but Ive ran over 600 lb springs with a 640 lift roller cam. Yes the shafts do show some galling but besides that they've held up pretty good.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
