Comp Cams Pro Magnum 440 Steel Rockers ?? #559763
12/22/09 03:01 AM
12/22/09 03:01 AM
Wisconsin USA
Albert Lee Offline OP
Wisconsin USA
Has anyone used the subject rockers on a 500 Hp drag race 440 with a .590" lift, solid lifter cam. This is in a 11 second B body with 440 Source heads and a 727 automatic.
Thanks in advance for your comments!
Re: Comp Cams Pro Magnum 440 Steel Rockers ?? [Re: Albert Lee] #559764
12/22/09 03:03 AM
12/22/09 03:03 AM
tboomer Online work
tboomer  Online Work
Hi,Al! Give us some more info about your combo..
Re: Comp Cams Pro Magnum 440 Steel Rockers ?? [Re: tboomer] #559765
12/22/09 03:22 AM
12/22/09 03:22 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
I believe the rockers are only rated for 350 LB or less open spring pressures.
Leave the gun.......take the Cannoli's....Mike
Re: Comp Cams Pro Magnum 440 Steel Rockers ?? [Re: Albert Lee] #559766
12/22/09 10:20 AM
12/22/09 10:20 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
No, but I have used them on a 499.75RWHP 451ci b engine with a .630 roller
Re: Comp Cams Pro Magnum 440 Steel Rockers ?? [Re: Albert Lee] #559767
12/22/09 12:10 PM
12/22/09 12:10 PM
organ
maximum entropy Offline
organ
iirc comp say they are good to ~ 400 pounds. they can be bushed to increase load capacity, as the problem with them at high pressure has been galling of the shaft.
Re: Comp Cams Pro Magnum 440 Steel Rockers ?? [Re: maximum entropy] #559768
12/22/09 01:03 PM
12/22/09 01:03 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Ive ran a set for 4 years and about 5000 miles with at least 400 passes with them. There not "recommended" for spring pressure over 350 ish, but Ive ran over 600 lb springs with a 640 lift roller cam. Yes the shafts do show some galling but besides that they've held up pretty good.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Comp Cams Pro Magnum 440 Steel Rockers ?? [Re: Albert Lee] #559769
12/22/09 01:52 PM
12/22/09 01:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I used em on my last 470 combo w/a solid Isky cam at .590-.610 lift and went mid 10`s and drove it everywhere for 4+ years and sold em to get my H-sharps for the roller I now run. They`re still going strong in another combo.
