Re: Indy Head Oiling / World Block [Re: atoetly] #559484
12/23/09 01:16 AM
12/23/09 01:16 AM
sg66mopar Offline
sg66mopar  Offline
I agree that there's probably no need to plug the holes. Like Allen said, with the -1 Indy's there's nowhere for the oil to go, except maybe out around a less than perfect head gasket seal. Wanting to eliminate any potential oil leak source I went ahead and plugged them.
Re: Indy Head Oiling / World Block [Re: sg66mopar] #559485
12/23/09 03:23 AM
12/23/09 03:23 AM
U.S.
moparniac Offline OP
U.S.
My block's back at the machine shop right now but it's the same as yours.
The oil galleries I circled on your picture are what supplies the oil to the rocker stands. They should be drilled and tapped, with a set screw installed? Look down in the two holes from the face of the block. I think its about a 3/8-16 black oxide coated set screw with a .040 hole through the middle.
Yea thats what was confusing me as in andyf's book his world block dont look like mine either! I must have gotten a prototype block... everyone always tricking WeDgiE
Mopar Performance
Re: Indy Head Oiling / World Block [Re: Bob_Coomer] #559486
12/23/09 03:29 AM
12/23/09 03:29 AM
U.S.
U.S.
One more thought....
The Indy kit does a great job of oiling the rockers on stock blocks..It wont be much diff than a aftermarket block cause your pulling oil from basically the same place.
I was told that oil up through the pushrods was good for harmonics also
Mopar Performance
Re: Indy Head Oiling / World Block [Re: sg66mopar] #559487
12/27/09 09:45 AM
12/27/09 09:45 AM
U.S.
U.S.
not plugged....
Mopar Performance
Re: Indy Head Oiling / World Block [Re: sg66mopar] #559488
12/27/09 07:29 PM
12/27/09 07:29 PM
U.S.
U.S.
what did you use???
Mopar Performance
Re: Indy Head Oiling / World Block [Re: moparniac] #559489
12/27/09 08:21 PM
12/27/09 08:21 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The oil holes are 3/8" course thread.
Re: Indy Head Oiling / World Block [Re: Mopar_Rich] #559490
12/27/09 08:33 PM
12/27/09 08:33 PM
U.S.
U.S.
what type of plug from where i meant. thx
Mopar Performance
Re: Indy Head Oiling / World Block [Re: moparniac] #559491
12/27/09 08:53 PM
12/27/09 08:53 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I just bought a 3/8 hex plug from the local hardware store.
It's a "set screw".
Re: Indy Head Oiling / World Block [Re: moparniac] #559492
12/27/09 09:21 PM
12/27/09 09:21 PM
sg66mopar Offline
sg66mopar  Offline
My block had the set screws installed when I received it but they had the .040 oil holes in them. I just filled the holes with Permatex Ultra Black and let it set up a few days.
Re: Indy Head Oiling / World Block [Re: Mopar_Rich] #559493
12/28/09 02:29 PM
12/28/09 02:29 PM
U.S.
U.S.
It's a "set screw".
thx. I got them and put them in with the permatex black to let them setup in there
Mopar Performance
Re: Indy Head Oiling / World Block [Re: moparniac] #559494
01/04/10 03:28 PM
01/04/10 03:28 PM
U.S.
U.S.
Will the standard Indy oil line kit to the heads work with a aluminum world block! also I was curious about restricting oil to the heads cause I will have pushrod oiling also... here is a reference pics! seem logical. thx
Well my oil line kit showed up today from mancini and I guess I dont have to worry about tapping the brass fittings as I guess the new kits come this way! also in the kit I got the little set screw plug to block oil to the top end!
Mopar Performance
Re: Indy Head Oiling / World Block [Re: moparniac] #559495
01/04/10 04:07 PM
01/04/10 04:07 PM
sg66mopar Offline
sg66mopar  Offline
Looks like you're good to go.
Re: Indy Head Oiling / World Block [Re: moparniac] #559496
01/04/10 04:35 PM
01/04/10 04:35 PM
NC
440Jim Offline
440Jim  Offline
NC
Is that pic the block plug or the oil line for the heads? That hole looks a lot bigger than 0.062" dia.
Re: Indy Head Oiling / World Block [Re: 440Jim] #559497
01/04/10 04:53 PM
01/04/10 04:53 PM
U.S.
U.S.
goes into heads......
Mopar Performance
Re: Indy Head Oiling / World Block [Re: moparniac] #559498
01/11/10 08:43 PM
01/11/10 08:43 PM
U.S.
U.S.
bump
Mopar Performance
Re: Indy Head Oiling / World Block [Re: 440Jim] #559499
01/11/10 08:44 PM
01/11/10 08:44 PM
U.S.
U.S.
yes its .110
Mopar Performance
Re: Indy Head Oiling / World Block [Re: Al_Alguire] #559500
01/14/10 06:38 PM
01/14/10 06:38 PM
U.S.
U.S.
No pushrod oiling is a good idea..Running the Indy lines is the bad idea...Actually they are ok but if I were to choose I would go pushrod oiling with the correct rockers for it.
So No indy oil line kit with T&D's ...
Mopar Performance
