Another sway bar question--Autoxcuda!
#559059
12/21/09 08:28 AM
12/21/09 08:28 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Or anyone else who wants to chime in!
I've heard that the ends of a sway bar need to be parallel to the ground for their maximum effectiveness...is this true? I would think that the angle of the sway bar is irrelevant, but that the length of the ends from the center of the bar, and the diameter/spring rate of the bar are all that matters?
I added a rear sway bar from a Dakota R/T to my truck, but I've also got a Hotchkis 2/3 drop, so my rear is 3" lower than "factory" which is 2" lower than a stock R/T would be, since the R/Ts had a 1" drop from the factory.
See this pic, my sway bar is angled down at nearly a 45 degree angle...do I need shorter "dog bones"
**Photobucket sucks**
Re: Another sway bar question--Autoxcuda!
[Re: 70Cuda383]
#559061
12/21/09 03:43 PM
12/21/09 03:43 PM
Posts: 27,465 So Cal
autoxcuda
So Cal
Yes, it is reduced. It's sort of like mounting shock at an angle. I'd call Hotchkis and ask if they have a fix or suggustions. But shortening the end link to get the sway bar arm perpendicular to the end link at ride height would fix it. Quote:
[Re: autoxcuda]
#559062
12/21/09 04:29 PM
12/21/09 04:29 PM
70Cuda383
Marysville, O-H-I-O
Yes, it is reduced.
Hmm. Ok.
I know what hotchkis' solution will be: "buy more of our stuff! may we recommend to you our complete TVS system?"
I've heard that shorter "dog bones" are available, I've just not looked very hard at finding any. I might just try making my own set, since those parts are NOT sprung steel like the bar...infact, the factory pieces are some sort of light weight phenolic material. shouldn't be too hard to fabricate something out of some mild steel...just gotta get to the scrap yard to find some good stock to work with.
[Re: autoxcuda]
#559063
12/21/09 05:06 PM
12/21/09 05:06 PM
Posts: 6,516 Santa Cruz, California
Lefty
And use heim joints to tighten up the handling to go with the lowered center of gravity.
[Re: Lefty]
#559064
12/21/09 05:47 PM
12/21/09 05:47 PM
70Cuda383
Marysville, O-H-I-O
it handles pretty well already! I love the hotchkis springs, significantly stiffer than stock spring rates, even with stock/OEM sway bars, it's flat through turns and feels well balanced, although I'm still searching for the limits, so I'm not sure where the balance is exactly, I don't know if it wants to understeer or oversteer. although, with a little bit of throttle, it will oversteer quite easilly
my only complaints about the suspension is that it does hit pretty hard on larger bumps, and with these stiffer springs, I'm probably not getting a lot of suspension travel on launch at the track, so it's costing me 60' times and ET
