I run 245/60-15's on a 15x7 steelie with 4-1/4" backspace in the rear on mine. This is the perfect wheel, in my opinion, as it centers up perfectly. The 245/60's fit really well, with about 3/4" on each side clearance (just enough to get your hand up inside the wheel well to clean the tires when you wash the car). If you're looking to have reasonable clearance and not have any rubbing, I think mine is the optimum setup. However, if you're just looking for the widest tire that will possibly fit, You could go a little bigger. I'm sure 255's would still fit pretty well, or obviously 70 series tires would fill up the wheelwell a little more.
