383/440 HP carb bolt markings ? #558594
12/20/09 04:14 PM
12/20/09 04:14 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
What did the head on the carb hold down bolts look like, did they have an H, or R.S.C. ? or???
Re: 383/440 HP carb bolt markings ? [Re: ademon] #558595
12/20/09 04:42 PM
12/20/09 04:42 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
68-70 TYPICALLY is the H
71-72 is TYPICALLY is the dogbone
RSC, I can honestly say I've never seen.
Then again , I have serious doubts I've seen them all .
studs and nuts TYPICALLY is 67 and down ( hemi excluded) ALTHOUGH I am almost positive both of my 69 GTX's were studs and nuts, but the cars are long gone .
Re: 383/440 HP carb bolt markings ? [Re: gtx6970] #558596
12/20/09 05:22 PM
12/20/09 05:22 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
It's an H
Re: 383/440 HP carb bolt markings ? [Re: ademon] #558597
12/20/09 05:30 PM
12/20/09 05:30 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Re: 383/440 HP carb bolt markings ? [Re: badblack68] #558598
12/20/09 08:39 PM
12/20/09 08:39 PM
Warrenton, VA
Warrenton, VA
Bill Alphin at A&M Hi-Tech obviously has them. They are only $3.00 each. Studs were on the Hemi AFB's. 69 AVS's had the H bolts
Re: 383/440 HP carb bolt markings ? [Re: RoadRunnerJD] #558599
12/20/09 08:49 PM
12/20/09 08:49 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah but badblack68 has them too & he'd rather you go to his Ebay store & pay about $5.00 pr bolt...
Re: 383/440 HP carb bolt markings ? [Re: gtx6970] #558600
12/20/09 09:29 PM
12/20/09 09:29 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
Bill werent some of them at that time studs in the rear and bolts in the front ??
Re: 383/440 HP carb bolt markings ? [Re: stateline] #558601
12/20/09 10:22 PM
12/20/09 10:22 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Not on a 4 bbl that I'm aware of.
2 bbl is a possibility
Re: 383/440 HP carb bolt markings ? [Re: RoadRunnerJD] #558602
12/21/09 10:33 AM
12/21/09 10:33 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Have used A&M Hi-Tech, Bill is great to talk to, good price on parts.
Re: 383/440 HP carb bolt markings ? [Re: ademon] #558603
12/21/09 12:08 PM
12/21/09 12:08 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
318 2bbl motors of that era used 2 bolt - 2 studs & the 383 - 2bbl use 4 studs.
Butch
