904 transmission tools #558446
12/20/09 12:44 PM
12/20/09 12:44 PM
Michigan Troll
blk00rt Offline OP
blk00rt  Offline OP
Michigan Troll
I think I am going to try rebuiling one of my spare 904 trans, what special tools do you really need to do these? what tools can you make? any sketches would help too.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: 904 transmission tools [Re: blk00rt] #558447
12/20/09 12:51 PM
12/20/09 12:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You will need a couple snap ring pliers and a compressor for the big spring in the front drum. Other than that just sockets and wrenches should do it.
Oh yeah and lots of brake cleaner
Re: 904 transmission tools [Re: HotRodDave] #558448
12/20/09 03:01 PM
12/20/09 03:01 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
need to replace bushing in tail shaft...pump and front drum...
can take thoses to a trans shop if bushing drivers are not available.
Tony
70 AARCuda Vitamin C
Re: 904 transmission tools [Re: blk00rt] #558449
12/20/09 04:46 PM
12/20/09 04:46 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
A list of some tools that will make it easier, but not absolutely needed
A 3/8x16 slide hammer to screw into the front pump to remove. Most pumps you can pop out from inside, but 904s set the pump in real deep, so sometimes it can be hard to pop it from inside.
Something to compress the spring assy on the front drum.
Snap ring(flat) pliars
Retaining ring(round) pliars
Bushing drivers or a bushing cutting chisel to remove any worn bushings. You can press new bushings in with a socket or similiar
A 904 is very basic to build. Leave the low spring and roller assy in the case. Do not remove it unless it is bad
Unless you are using a Shift Kit, build it back to the same specs as OE. Do not listen to some who say tighten this, or loosen that. This trans has been around for almost 50 years and has worked well,even stock!
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 904 transmission tools [Re: zzyzxpat] #558450
12/20/09 06:55 PM
12/20/09 06:55 PM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
I would add inch-pound,and foot-pound torque wrenches to the must-have list.You should also check the 7 digit PN to find out what year of trans you are working on before you order parts.The correct year of service manual would also be a big help for a first-timer.
Re: 904 transmission tools [Re: bigslant6fan] #558451
12/20/09 11:26 PM
12/20/09 11:26 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I used this and a C-clamp to compress the spring assy on the front drum in a 727 I rebuilt. I threw it together in about 10 minutes with some scraps I had laying about. Never thought I'd need it again so its a real cobble job, but it worked so well I kept it. Now I will be using it on my 904 soon
Re: 904 transmission tools [Re: Scott Carl] #558452
12/20/09 11:43 PM
12/20/09 11:43 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
904 drum is alot smaller..might need a smaller diameter ring...
Tony
Re: 904 transmission tools [Re: 70AARcuda] #558453
12/21/09 02:11 AM
12/21/09 02:11 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Ratz!!
But thanks for the heads up
