P/N and date code #558164
12/19/09 08:58 PM
12/19/09 08:58 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
I am in the process of my first super high end restoration and would like your input. My client wants a near perfect numbers matching car. What is more important – part number or date code? Lucky for me this car came with correct motor, tranny, carbs and rear axle. But he is missing the correct alternator, starter, exhaust manifolds, etc (the little things). I can find the correct part number items to replace, but am not finding the correct (acceptable) date codes on these items. How do others handle this issue?
Re: P/N and date code [Re: TrueTripleX] #558165
12/19/09 09:49 PM
12/19/09 09:49 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I personally try to get the right part # as that is easier (usually)and satifies my needs, but for a true "super high end resto", you will need to have both... No small feat
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: P/N and date code [Re: 70440+6bbl] #558166
12/19/09 10:17 PM
12/19/09 10:17 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
Recently I went through the same thing! I'll use the starter as an example. I had to buy a real nice starter that had the correct part number and date code on the aluminum snout. Then I had to buy another starter that had the right part number and date code on the barrel. It's getting hard to find parts that havn't been blasted to the point of no return. Years ago the rebuild shops would tear them down and throw the components into bins. Worse yet sometimes they would remove all original part numbers and date codes and replace them with their logos. Make a list and start searching!
Re: P/N and date code [Re: TrueTripleX] #558167
12/19/09 10:18 PM
12/19/09 10:18 PM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
Well if you're coming from the Chevy world you know the answer, simply restamp it to your liking!
Seriously, for a top dollar resto like you describe you need both. And I would say those items you listed above are the "little things" that separate the crap from the nicer cars. If you can have just one PN is more important.
What kind of car are we talking about?
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
Re: P/N and date code [Re: sg333e] #558168
12/20/09 11:52 AM
12/20/09 11:52 AM
Ball Ground GA
Ball Ground GA
Car is a 68 hemi road runner.
Re: P/N and date code [Re: TrueTripleX] #558169
12/20/09 01:23 PM
12/20/09 01:23 PM
California
1970mopar Offline
1970mopar  Offline
California
Sounds like a great project.
You stated that the restoration was to be a "high End" resto with correct parts.
So to answer your question: Part numbers and Date codes are both needed for a 100% correct "high end" restoration.
Also needed is a knowlege of correct component and hardware finished- (what parts are painted, left bare metal, correct platings on nuts, bolts, brackets, etc.)
Easy, search... search... search... talk around, post wanted adds, make tons of phone calls, etc. - don't expect to find everything easily - it takes time (sometimes up to a year for some extremely hard to find parts)- make sure you explain this to your customer ahead of time.
If your customer has an unreasonable expectation on doing the project in a short timeframe, your going to be having alot of issues. From what you stated alot of the major parts are there, however, as with most "projects" all or most of the little parts are missing... Just remember its the little things that make the differences.
Good luck with your project. Take your time and do your research.
Re: P/N and date code [Re: TrueTripleX] #558170
12/20/09 01:26 PM
12/20/09 01:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
You've answered your own question, pt # AND date code will be required.
Me peronally I'll look for both.
And if I don't find a part that fits my requirement, I MIGHT (I doubt it though) settle for just the correct pt number. But I'll always be looking for that better pt with the correct date.
Talk to Jim Ridge and see if he can help you on the starter and/or alternator cores
Re: P/N and date code [Re: 1970mopar] #558171
12/20/09 01:35 PM
12/20/09 01:35 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
So to answer your question: Part numbers and Date codes are both needed for a 100% correct restoration.
And Pete would know having built an OE quality car before.
You can get away with some things but by in large the judges will pick up on most inconsistancies wheather it be part#, date code, or correctness in the finish details. If you are going for O.E. judging you better bring your "A Game".
If you are new to this level of restoration you might want to ask your customer to tell you which judging level he plans on shooting for if that's a goal of his, then you should consult with the judging body of choice to get as much detail as required before you continue too far. Starting with a complete car is hard enough, starting with a car missing so many detail items can be a MAJOR challenger these days in gathering the correct ones, sometimes impossible. If his goal is to achieve OE Gold status he may have started with the wrong car simply because so many key original parts are missing. Most shops I'm familiar with leave the parts finding work to the cars owner, or charge a very high premium for seeking them out due to the time involved in finding them, and the usual $ premiums they can bring when found. BTW, a 68 Hemi car is no easy restoration, LOTS of small detail items vary on those cars, it was a transitional year.
Re: P/N and date code [Re: ScottSmith_Harms] #558172
12/21/09 12:15 PM
12/21/09 12:15 PM
Ball Ground GA
Ball Ground GA
Thanks Scott, Bill and the rest. I knew what you were going to say. You should also know that this car is going to be a driver, and will never go for judging. The guy just wants it "right". But I will do as he request. He will have to understand that right takes time. But for a driver, is this extra time worth it?
Re: P/N and date code [Re: TrueTripleX] #558173
12/21/09 12:21 PM
12/21/09 12:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's all up to him to decide. Personally I'd find the absalute correct componants when the opportunity arrises (date codes, part#'s, etc.) and store them for someday, while running correct appearing replacement parts for driving duty.
