'00 Concorde Heater Problem, Very Strange
#557450
12/19/09 01:18 AM
12/19/09 01:18 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
The heater in our '00 Concorde has a very strange problem. Since last winter the heater hasnt blown as hot as it used to. Tonight I noticed that when you come to a stop the air out of the vents gets considerably cooler, take off and the air heats back up. I also noticed this evening the temp gauge is reading a little warmer than usual, not much but enough to notice, usually runs about 3/8 on the temp gauge, tonight it was right at the halfway mark. Any ideas? Thank
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: '00 Concorde Heater Problem, Very Strange
[Re: Von]
#557452
12/19/09 11:07 AM
12/19/09 11:07 AM
Posts: 4,946 WI
Dcuda69
WI
Any ideas?
Thank
Low coolant level???
[Re: stumpy]
#557454
12/21/09 01:58 PM
12/21/09 01:58 PM
Von
NE Oklahoma
So, I think you are right that it is low on coolant. Looks like the rad is leaking and Ive got to refill it to locate the leak.
So, is there a way to refill properly without having to have the 50 dollar funnel?
