Re: window nets
[Re: barracudabob]
#557339
12/18/09 11:26 PM
12/18/09 11:26 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Give me a minute and I'll go take some pics of mine
Re: window nets
[Re: barracudabob]
#557341
12/18/09 11:30 PM
12/18/09 11:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm trying to figure out how to mount a window net in my car. The problem I am having is how to secure the bottom to the cage. Anyone have any pictures/advice/comments? Thanks in advance, Bob
here is a mounting kit http://www.rjsracing.com/windownets.html
Post deleted by Defbob
[Re: barracudabob]
#557342
12/18/09 11:34 PM
12/18/09 11:34 PM
Re: window nets
#557344
12/18/09 11:46 PM
12/18/09 11:46 PM
WILD BILL
BROOK PARK, OH
OK, here's mine. I messed up and mounted it on the outside of the cage.
This winter I'll be remounting it to the inside like it's supposed to be
[Re: WILD BILL]
#557348
12/19/09 02:10 PM
12/19/09 02:10 PM
Re: window nets
#557349
12/19/09 02:17 PM
12/19/09 02:17 PM
MR_P_BODY
it's hard to explain with out pics but here's a try if you use a net with an angle on the bottom .
you can weld two small lengths of tube on the shoulder bar slightly wider than the net. put a rod thru the net and it slides right into those tubes. you put the rod into the front tubes first and slide it toward and into the rear tube. a pin holds it in place. 'I know no pics
Thats what I use for my bottom bar on my net, has the seat belt lock on top.... right now the top slides into a tube(like the bottom) at the rear and the seat belt lock at the front.... I'm going to change the top rear point to a hinge
