window nets #557338
12/18/09 11:23 PM
12/18/09 11:23 PM
Saskatchewan, Canada
barracudabob Offline OP
I'm trying to figure out how to mount a window net in my car. The problem I am having is how to secure the bottom to the cage. Anyone have any pictures/advice/comments? Thanks in advance, Bob
Re: window nets [Re: barracudabob] #557339
12/18/09 11:26 PM
12/18/09 11:26 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Give me a minute and I'll go take some pics of mine
Re: window nets [Re: barracudabob] #557340
12/18/09 11:29 PM
12/18/09 11:29 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
mine uses a cable that goes around the lower bar
Re: window nets [Re: barracudabob] #557341
12/18/09 11:30 PM
12/18/09 11:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
here is a mounting kit
http://www.rjsracing.com/windownets.html
Post deleted by Defbob [Re: barracudabob] #557342
12/18/09 11:34 PM
12/18/09 11:34 PM
Re: window nets #557343
12/18/09 11:45 PM
12/18/09 11:45 PM
Yes, its a square net, ribbon style. The problem I'm having is how to attach the forward mount, so it can be easily taken down to make entry and exit easier. Bob
Re: window nets #557344
12/18/09 11:46 PM
12/18/09 11:46 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
OK, here's mine. I messed up and mounted it on the outside of the cage.
This winter I'll be remounting it to the inside like it's supposed to be
Re: window nets [Re: WILD BILL] #557345
12/18/09 11:51 PM
12/18/09 11:51 PM
I gather it is legal to have the bottom front rod mounted with a cable or strap? Bob
Re: window nets [Re: barracudabob] #557346
12/18/09 11:53 PM
12/18/09 11:53 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Yes. Or at least no one has said otherwise to me yet.
Re: window nets [Re: WILD BILL] #557347
12/19/09 12:26 PM
12/19/09 12:26 PM
Thanks for the pics, Bill. Bob
Post deleted by Defbob [Re: WILD BILL] #557348
12/19/09 02:10 PM
12/19/09 02:10 PM
Re: window nets #557349
12/19/09 02:17 PM
12/19/09 02:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
it's hard to explain with out pics but here's a try if you use a net with an angle on the bottom .
you can weld two small lengths of tube on the shoulder bar slightly wider than the net. put a rod thru the net and it slides right into those tubes. you put the rod into the front tubes first and slide it toward and into the rear tube. a pin holds it in place.
'I know no pics
Thats what I use for my bottom bar on my net, has
the seat belt lock on top.... right now the top
slides into a tube(like the bottom) at the rear and
the seat belt lock at the front.... I'm going to
change the top rear point to a hinge
