small block cam #556205
12/17/09 01:30 PM
12/17/09 01:30 PM
OHIO U.S.A.
DUSTER51 Offline OP
DUSTER51  Offline OP
OHIO U.S.A.
does anyone know anything about this cam the part number on the end of the cam is 221285 I took it out of a 340
Re: small block cam [Re: DUSTER51] #556206
12/17/09 03:10 PM
12/17/09 03:10 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Do you have any idea who made it????
Re: small block cam [Re: MIKES_DUSTER] #556207
12/18/09 03:44 PM
12/18/09 03:44 PM
OHIO U.S.A.
DUSTER51 Offline OP
DUSTER51  Offline OP
OHIO U.S.A.
dont know who made it it was in a 340 it is new but I dont know anything about it so I went with a new cam and lifters and springs .
Re: small block cam [Re: DUSTER51] #556208
12/22/09 11:56 AM
12/22/09 11:56 AM
Re: small block cam [Re: MIKES_DUSTER] #556209
12/22/09 01:20 PM
12/22/09 01:20 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yoou could figure out the lift for your self by measuring across the diameter and then again at tha peak of the cam to the base circle, subtract and multiply by 1.5 if that is what you want.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
