How much NOS will a cast crank take #555785
12/16/09 09:45 PM
12/16/09 09:45 PM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
A friend wants to put NOS on his car with a stock 360 cast crank and stock rods ross pistons what would be a safe amount .I told him lets build a good steel crank and h beam rods motor together frist then put the NOS to it
Re: How much NOS will a cast crank take [Re: scottb] #555786
12/16/09 09:55 PM
12/16/09 09:55 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We sprayed the piss outa a pretty much stock 360 with 125 shot, only thing was ring gap set up for the shot and arp rod bolts and reduced timing when spraying,beware.... its fun
Re: How much NOS will a cast crank take [Re: scottb] #555787
12/16/09 09:55 PM
12/16/09 09:55 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
I have always heard that a stock engine could take a 150 hp shot of nitrous. I ran my magnum motor at this level for 3 years before I build my 408.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: How much NOS will a cast crank take [Re: blk00rt] #555788
12/16/09 10:26 PM
12/16/09 10:26 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
been sprayin a stock 360 bottom end since o4
.63 and .78 jets depending on track.. on a big shot plate.
seems to be taking it...?
dont know what that computes to ?
it is polished rods and lightend rotating assy.
with K.B. hypers..
fwiw..
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: How much NOS will a cast crank take [Re: cheapstreetdustr] #555789
12/16/09 11:02 PM
12/16/09 11:02 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
i had a stock 360 bottom end with forged repl pistons, Stock crank stock rods etc, In my car it ran 13.00 on motor and 10.90 with nitrous, It had two plates stacked for a two stage, both jetted at 175each so yea that was 350hp on a stock crank stock rod motor. Keep it out of detonation youll be surprised at what lives..Id keep it to 175 though and you should be ok. A 360 cast crank is pretty beefy
....BAD A$$ STREET CAR.....
Re: How much NOS will a cast crank take [Re: n20mstr] #555790
12/16/09 11:06 PM
12/16/09 11:06 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Detonation is your biggest enemy
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: How much NOS will a cast crank take [Re: bigtimeauto] #555791
12/17/09 09:58 AM
12/17/09 09:58 AM
Toronto
mshred Offline
mshred  Offline
Toronto
when you all say stock bottom end, are the ring gaps and rings themselves stock as well?
Re: How much NOS will a cast crank take [Re: mshred] #555792
12/17/09 11:25 AM
12/17/09 11:25 AM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
As far as i know the rings are not cut for NOS
Re: How much NOS will a cast crank take [Re: n20mstr] #555793
12/17/09 02:40 PM
12/17/09 02:40 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
1973 Brasilian Dart
E100, boosted 390"
Re: How much NOS will a cast crank take [Re: cheapstreetdustr] #555794
12/17/09 03:36 PM
12/17/09 03:36 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
with K.B. hypers..
fwiw..
cheapst.
.068 around 200hp .078 around 275hp
most stock engines can take a 150 shot with no problems, as long as you take timing out and run good fuel, might have to put a colder plug in. just keep reading the plugs.
Re: How much NOS will a cast crank take [Re: blk00rt] #555795
12/17/09 08:37 PM
12/17/09 08:37 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
blk00rt did your magnum motor have hyperutectic pistons when you were spraying N.O.S. on it.If it did,were the rings gapped bigger for it.I have a 360/380hp crate motor and I was wanting to try spraying it without regapping the rings.Maybe 100 or 125.I only run 1/8 mile.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: How much NOS will a cast crank take [Re: D-50] #555796
12/17/09 08:54 PM
12/17/09 08:54 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
the 360 magnum was a completly stock lower end. It had hyper pistons and rings were never touched. I ran it for 2-3 years on the stock bottom block until I decided to change to the 408.
Rob Dunn
1976 Dart Sport 360
2009 Jeep Patriot
Re: How much NOS will a cast crank take [Re: Sub95] #555797
12/17/09 09:01 PM
12/17/09 09:01 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
I always thought .082 was about 200
Re: How much NOS will a cast crank take [Re: blk00rt] #555798
12/17/09 09:10 PM
12/17/09 09:10 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Thanks for the info.Did you say you sprayed 150 on it?
Re: How much NOS will a cast crank take [Re: D-50] #555799
12/17/09 09:18 PM
12/17/09 09:18 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
There's a number of guys on the Dakota R/T Forums spraying 150 on stock bottom ends, and have been for years...
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: How much NOS will a cast crank take [Re: D-50] #555800
12/17/09 09:59 PM
12/17/09 09:59 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
"Thanks for the info.Did you say you sprayed 150 on it?"
yes, I do have a timing retard unit and I pull 1-2 degrees out but I dont really have to, I do it just to be safe.
Rob Dunn
1976 Dart Sport 360
2009 Jeep Patriot
Re: How much NOS will a cast crank take [Re: Adobedude] #555801
12/17/09 10:00 PM
12/17/09 10:00 PM
Sue Offline
Sue  Offline
Thats no different than How many licks to the center of a Tootsie Roll Pop.
It will take just enough to brake it
Re: How much NOS will a cast crank take [Re: Sue] #555802
12/17/09 10:07 PM
12/17/09 10:07 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I think you will find that the crank shaft is not the weak link, Its every thing that sits behind it
Re: How much NOS will a cast crank take [Re: emarine01] #555803
12/17/09 10:28 PM
12/17/09 10:28 PM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
Got a stock bottom end 400,I mean stock.I have hit this motor with 250 forever.Keep the timing out and all will be good.Lenny
Re: How much NOS will a cast crank take [Re: 8secDart] #555804
12/18/09 01:32 AM
12/18/09 01:32 AM
Toronto
mshred Offline
mshred  Offline
Toronto
what's the max you can spray without regapping the rings?
