i was wanting sum opinions on a new build. currently running 446 12.5 cr hughes 232/237 110 lsa cam hughes stage2+ 452's and hughes ported eddy rpm intake. i run in a limited vacuum class (15"@900)for mud drags.
just bought a 512 shortblock with 440 source kit. plan to use my old heads and intake but was wanting to switch cams since the larger dispacement should make more vacuum.
thinking of a going to a cam with 246/250
dur@.050 and having it ground on 112lsa instead of 108. i guess im just wanting to know if the 112 lsa will screw things up?? i had read that larger disp will like a little more lsa.
