W2 heads #555462
12/16/09 02:34 PM
12/16/09 02:34 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...i have long considered building a W2 headed smallblock.
i know there are easier ways to make smallblock power without the specific rockers and so on that go along with the W2 heads.
that being said, i've been following different posts and realize there are differences among them.....what should i look for?
any info appreciated...al
..there's a Duster with a 340 in it.. they've got some muscle here tonight.
Re: W2 heads [Re: can.al] #555463
12/16/09 02:41 PM
12/16/09 02:41 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
In a nutshell you have Race W2 and Econo W2's. Race have flat milled surface for a indpendent pedestal to locate the rocker shafts, the Econo's have a cast in rocker pedestal, similar to stock style rockers.
The race version has offset rocker stands and they require a fair amount of work to set up correctly, but just takes time. Either head will most likely require pushrod clearances, sometimes significant. Both can make good power for the dollar if you buy them right. The race rocker set ups just cost more.
RIP Monte Smith
Re: W2 heads [Re: CompWedgeEngines] #555464
12/16/09 02:49 PM
12/16/09 02:49 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..so there are no years were certain castings were better or poorer quality?
Re: W2 heads [Re: CompWedgeEngines] #555465
12/16/09 02:53 PM
12/16/09 02:53 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
looking at the harlan sharp rockers the race kit is about $1100.00 which includes rockers, shafts, and blocks.
the econo head kit is $990.00 which includes the shafts and rockers.
these prices are taken from summit racing...just for reference.
Tony
70 AARCuda Vitamin C
Re: W2 heads [Re: 70AARcuda] #555466
12/16/09 03:05 PM
12/16/09 03:05 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
If you decide to go race W2, check with Brian at IMMengines, he has some MP race rocker gear for sale.
Re: W2 heads [Re: 70AARcuda] #555467
12/16/09 03:12 PM
12/16/09 03:12 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I have used the econo W2 heads with the Mopar Performance offset rockers for 8 years plus on a dirt track 408" motor with NO problems. I use solid/flat tappet cam,,NO roller. If you re going roller, it costs mucho' more to get heads to work proper. Mine are standard valve length heads with a 130#/330# spring set up, .580"-ish lift. No push rod clearance issues.
If you like drag racing, support your local track.
Re: W2 heads [Re: CHAPPER] #555468
12/16/09 03:35 PM
12/16/09 03:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Before you spend any money, I would suggest talking to Ryan at Shady Dell - member here, knows his way around W-heads and the other SB heads available.
I have a Batten-W2-headed SB, and it's certainly not embarrassing, but technology has a way of moving forward...
Re: W2 heads [Re: CHAPPER] #555469
12/16/09 03:40 PM
12/16/09 03:40 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Not to hi-jack this thread but is there any HP/TQ differences between the RACE and ECONO heads??
Re: W2 heads [Re: topside] #555470
12/16/09 03:44 PM
12/16/09 03:44 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...what is the horsepower/flow potential of stock econos with a streetable solid cam?
not looking at a stroker right now...
Re: W2 heads [Re: can.al] #555471
12/16/09 04:08 PM
12/16/09 04:08 PM
Finland
mafo Offline
mafo  Offline
Finland
We discussed w2 heads here, maybe you can find some
info
https://board.moparts.org/ubbthreads/show...e=3#Post5663318
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: W2 heads [Re: can.al] #555472
12/16/09 04:41 PM
12/16/09 04:41 PM
Syracuse,NY
Syracuse,NY
Yes, there ARE early castings you want to stay away from. I have a set here. They are very prone to cracking around the head bolt bosses, particuarily on the outside bolt holes. The later castings have more meat and "bracing" in this area.
RIP Monte Smith
Re: W2 heads [Re: MIKES_DUSTER] #555473
12/16/09 04:53 PM
12/16/09 04:53 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Of the same generation NO... Race & Econo's use same ports/chambers. Only difference is the rocker pedestals in the heads.
As a general rule....anything that has the actual word MOPAR & W2 cast into them would be better head to start with (eliminates the older stuff)
It's hard to make generalizations about W2's because they have been made for 36 years, & there are so many different variations that have been made over the years it gets mind boggling.
Just off top of my head......
47CC closed chamber
55CC closed chamber
60CC open chamber
65CC closed chamber
2 different 70-72CC open chambers
3 basic outside castings (1970's/late '80's/Late 90's) All with differing strengths
18 degree valve angle
15 degree valve angle
at least 4 different intake port designs & 4 different exhaust port designs....
Long valve econo, std. length econo...
Traditional Race W2 rocker gear & now T&D/Jesel rocker setups only....
Several different variations on header bolt patterns... some heads have dual pattern, some are single std, some single race....
They are like race blocks, so many different variations/versions, ask questions before you buy....
Re: W2 heads [Re: mafo] #555474
12/16/09 07:33 PM
12/16/09 07:33 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...yes,i had been through all of those posts.
actually it was the info on early water jacket design,problems w/cracks and so on that made me want a little more info.
there was a set on e-bay from Petty Racing that a fellow was selling in California.
anybody have a comment on them....i don't think they sold.
Re: W2 heads [Re: can.al] #555475
12/16/09 07:46 PM
12/16/09 07:46 PM
Syracuse,NY
Syracuse,NY
Econo W2 pushrod clearance. This was a 62o solid, a bit larger than needed, but not much extra room. I'll post some pushrod angles shortly.
RIP Monte Smith
Re: W2 heads [Re: CompWedgeEngines] #555476
12/16/09 07:54 PM
12/16/09 07:54 PM
Syracuse,NY
Syracuse,NY
Bare W2 Econo
RIP Monte Smith
Re: W2 heads [Re: CompWedgeEngines] #555477
12/16/09 07:57 PM
12/16/09 07:57 PM
Syracuse,NY
Syracuse,NY
Pushrod angles from farther back.
RIP Monte Smith
Re: W2 heads [Re: CompWedgeEngines] #555478
12/16/09 08:00 PM
12/16/09 08:00 PM
Syracuse,NY
Syracuse,NY
Glamour Shot...
Note the dual header bolt pattern.
RIP Monte Smith
Re: W2 heads [Re: CompWedgeEngines] #555479
12/16/09 10:58 PM
12/16/09 10:58 PM
Mississippi Gulf Coast
Mroctober Offline
Mroctober  Offline
Re: W2 heads [Re: CompWedgeEngines] #555480
12/17/09 12:10 AM
12/17/09 12:10 AM
Upland, California
Spode Offline
Spode  Offline
Upland, California
Im a rookie but wouldnt pushrod angles like that shown i about 15 degrees from the cam perpendicular reduce the gross lift about 25%
(cos)15=.75 +/-
Re: W2 heads [Re: Spode] #555481
12/17/09 12:14 AM
12/17/09 12:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
(cos)15=.75 +/-
Its no where near a 25% loss but it is some
