Page 3 of 3 1 2 3
Re: Cast Iron Max Wedge headers [Re: hemi71x] #555434
12/25/09 04:44 PM
12/25/09 04:44 PM
just a little bit of information for some of you guys that know alot about max wedge exhaust manifolds.
when hooked up to a full max wedge exhaust system,the cars made 425 hp from the factory but when you uncorked the blockoff plates,you were able to achieve an extra 80-90 hp. the power difference was very noticeable when going from corked to a uncorked exhaust system.
Re: Cast Iron Max Wedge headers [Re: Real-Fury] #555435
12/25/09 05:21 PM
12/25/09 05:21 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Those manifolds look really cool but imagine changing spark plugs around a cast iron radiator. The manifolds put off a ton of heat and raise hell with master cylinder. If you were going to drive the car and race it I would put headers on. If you were going to have a show car the manifolds would be fine.
Re: Cast Iron Max Wedge headers [Re: moparpollack] #555436
12/25/09 05:28 PM
12/25/09 05:28 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
I'm sure you would be changing spark plugs from the bottom, with the car up on a hoist, or on jack stands.
Probably wouldn't be much of a problem from the bottom.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Cast Iron Max Wedge headers [Re: hemi71x] #555437
12/25/09 06:07 PM
12/25/09 06:07 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
If you are trying to maximize your flow and horse power I would use the aftermarket headers. Not the over the counter pieces of crap headers you can buy at any speed shop. The money you spend in this area will reflect on the Dyno. There are reasons to use short tube or a long tube lengths and various other modifications to a header tube. Spend time on researching this stuff before you buy anything. Max Wedge repro manifolds will run you about 1000+ dollars. Then you can try and buy the rest of the exhaust system.
Your choices of exhaust all depends on the motor modifications and the uses you will have the car doing. Research research research.Dont waste money with an unsuited exhaust system.
1971 HEMI E BODY REGISTRY
Re: Cast Iron Max Wedge headers [Re: hemi71x] #555438
12/25/09 09:27 PM
12/25/09 09:27 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Actually,plugs are easier to change than with regular HP manifolds.
Re: Cast Iron Max Wedge headers [Re: hemi71x] #555439
12/25/09 10:13 PM
12/25/09 10:13 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Draginmopars had a set on his 68 Satellite 4 door racecar. I believe he said a portapower fixed the firewall issue.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Cast Iron Max Wedge headers [Re: 62maxwgn] #555440
12/25/09 10:27 PM
12/25/09 10:27 PM
hemi71x Offline
hemi71x  Offline
"The Orange Monster"
Re: Cast Iron Max Wedge headers [Re: hemi71x] #555441
12/25/09 11:10 PM
12/25/09 11:10 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Re: Cast Iron Max Wedge headers [Re: moparpollack] #555442
12/26/09 12:32 AM
12/26/09 12:32 AM
last time i checked headers make a ton of heat in
the engine compartment. exhaust manifolds do not.
sparks plugs as said are a breeze to change. those
Maxi Exhaust Mans don't give up a ounce of horsepower
to any modern header. they are alot heavier though.
but thats an excuse to put the battery in the trunk.
single master cylinders in the day did not suffer
the heat sink problem like modern dual master
cylinders will. but you can always had a heat shield
to help protect it.
Re: Cast Iron Max Wedge headers [Re: Michael] #555443
12/26/09 12:34 AM
12/26/09 12:34 AM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
WHAT IS UP ...with all that changin'-the-plugs ??.. !!
What you guys need is a good ignition system and a carb that will not "wipe-out" the plugs in the first place.
Last time I had my 62 out .. I had it up to 5400 in high-gear(with a 2.76 gear) ...and it never missed a beat.
And THOSE plugs were put in-there in 1979 ! (about 40k miles ago)
Re: Cast Iron Max Wedge headers [Re: dOc …] #555444
12/26/09 02:50 AM
12/26/09 02:50 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Heck yea I have had the same plugs in my 63 for almost 2 years and raced 5 times this year with them along with alot of street miles. Never had any problems and turned a new best et the last time out. But honestly I would love to see a back to back dyno test of the Maxie exh manifolds vs headers. Ron
Re: Cast Iron Max Wedge headers [Re: DaytonaTurbo] #555445
12/26/09 11:03 AM
12/26/09 11:03 AM
Minn
SportF Offline
SportF  Offline
Minn
I think if you guys had ever lifted a set of those cast iron headers you'd be surprised how little they do weigh. It is not that much heavier than TTI headers, if any. The intake manifold and carbs look heavy, but the manifold AND carbs weigh less than a stock cast iron 4 barrel manifold by itself.
Re: Cast Iron Max Wedge headers [Re: SportF] #555446
12/26/09 01:03 PM
12/26/09 01:03 PM
never layed my hands on some tti's but i know that the max wedge exhaust mans are heavier
then a set of hooker super comps. i do believe also that the original crossram intakes were made
from magnesium too. which is lighter then aluminum. not a 100% on mag use though.
383man there were a couple of dyno tests. the max mans were = to the headers for power making. the
exhaust that was standard on the max cars were tuned for it. the 3" pipe before the dumps was just
like collector extensions used today. i believe the max wedge cars destine for SS use came with
a single exhaust. IIRC. therefore i think thats where the "header makes more power" theory came from.
Re: Cast Iron Max Wedge headers #555447
12/26/09 01:41 PM
12/26/09 01:41 PM
Minn
SportF Offline
SportF  Offline
Minn
hemi's had a magensium intake, but I don't think they made max wedges in Magesium. Yes, most headers are real thin wall stuff. I compared the cast iron max exhaust to the TTI's as I have TTI's on my car and know they are about the same.
Re: Cast Iron Max Wedge headers [Re: SportF] #555448
12/26/09 03:37 PM
12/26/09 03:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Complete 3" TTI from the manifolds back,wouldn't trade for any headers.
Re: Cast Iron Max Wedge headers #555449
12/26/09 03:48 PM
12/26/09 03:48 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
All Max Wedge Cross Ram Intakes were aluminum
1964 Hemi Cross Rams were aluminum
1965 & 1968 Hemi Cross Rams were Magnesium. Some 65 Hemi cars might have had leftover aluminum intakes but I've never seen a documented example.
Re: Cast Iron Max Wedge headers [Re: ScottSmith_Harms] #555450
12/26/09 03:54 PM
12/26/09 03:54 PM
sorry, what i meant to say was the original ie: very early 413 crossrams. i remember discussing that
with a former MoPar SuperStock racer. i prolly misunderstood though. point noted and thanks for
clearing that up for me.
Re: Cast Iron Max Wedge headers [Re: 383man] #555451
12/26/09 07:04 PM
12/26/09 07:04 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I agree with 383man. I'd love to see a testing of maxie exhaust manifolds vs headers vs 68-69 roadrunner type manifolds.
This is the land of the free because of the brave
Re: Cast Iron Max Wedge headers [Re: rbstroker] #555452
12/27/09 12:43 AM
12/27/09 12:43 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Like I said earlier dont test the Factory Headers Exhaust Manifolds against that over the counter stuff. Even TTI and Hooker are made to fit first and flow second. Even with the factory header it does not work with every application or variable that a RB-B Motor can be use for. If you are looking for a cheaper exhaust that works ok use the headers that every speed shop sells. The Max Headers looks cool and works real well. Custom built race headers and exhaust system cost money. Go what every way you like,but research before you buy any of them.
Page 3 of 3 1 2 3
