340 Six Pack end carbs............ #555230
12/16/09 09:54 AM
12/16/09 09:54 AM
Anonymous OP
Anonymous OP
What sizes are the holes in the end plates from the factory? I've got a set here and it looks like these have been drilled......and the car is rich at WOT........
Re: 340 Six Pack end carbs............ #555231
12/16/09 10:06 AM
12/16/09 10:06 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
dont know the size of the holes but the hole would lean it out AT IDLE and would have no effect at WOT
Re: 340 Six Pack end carbs............ [Re: aarcuda] #555232
12/16/09 01:44 PM
12/16/09 01:44 PM
Anonymous OP
Anonymous OP
Say what??? I'm talking about the end plates that are the last things bolted on before you install the float bowl......
Re: 340 Six Pack end carbs............ #555233
12/16/09 01:54 PM
12/16/09 01:54 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
oh sorry. i thought you were talking about the holes in the throttle plates. I nust have missed the word END and read it as throttle plates.
I do have the numbers in my book at home but not here at work
Re: 340 Six Pack end carbs............ #555234
12/16/09 03:35 PM
12/16/09 03:35 PM
Az
Crizila Offline
Crizila  Offline
Az
Ether a part # on the metering plate or a carb list # would help.
Fastest 300
Re: 340 Six Pack end carbs............ [Re: Crizila] #555235
12/16/09 05:15 PM
12/16/09 05:15 PM
Anonymous OP
Anonymous OP
34R-6153-B
Re: 340 Six Pack end carbs............ [Re: Crizila] #555236
12/16/09 05:19 PM
12/16/09 05:19 PM
N.E. England
Roppa440 Offline
super street
Roppa440  Offline
super street
N.E. England
I can't find the factory spec just now but if they are on a stock Aluminum Edelbrock Manifold try these sizes;
----------------------------------Throttle Side--------- Diaphragm Side
Front Carburetor MMO------------- .086----------------------.073
Center Carburetor Jet-------------- #63---------------------- #63
PVCR--------------------------------- .046--------------------- .046
Rear Carburetor MMO--------------- .086-------------------- .073
Same as above but with heat cross-over blocked;
------------------------------------Throttle Side-------- Diaphragm Side
Front Carburetor MMO-------------- .086--------------------- .073
Center Carburetor Jet-------------- #64---------------------- #64
PVCR--------------------------------- .046---------------------- .046
Rear Carburetor MMO----------------.086--------------------- .073
2002 Chevrolet Corvette 5.7 LS1 2011 Alpha Romeo Giulietta Veloce 1.6 JTD Because running a Mopar in the UK is getting TOO expensive!!
Re: 340 Six Pack end carbs............ #555237
12/16/09 05:26 PM
12/16/09 05:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
.084 throttle side,.072 opposite side.Plate should be stamped 41
Re: 340 Six Pack end carbs............ [Re: 62maxwgn] #555238
12/16/09 07:05 PM
12/16/09 07:05 PM
Anonymous OP
Anonymous OP
Yes, it's stamped 41.......Thanks guys.......that's what I needed.....
