Re: Freakin' dipstick tube! Need help..
[Re: PJM]
#554988
12/16/09 10:05 AM
12/16/09 10:05 AM
Posts: 75,083 U.S.S.A.
JohnRR
U.S.S.A.
Thanks for the quick reply. No its a brand new crate engine.
is this the crap CHROME dipstick tube ?
[Re: PJM]
#554992
12/16/09 10:46 PM
12/16/09 10:46 PM
Posts: 736 New York
R/T1968R/T
New York
Heres the trick. Put a small cut in the end of the tube 1/4 to 3/8" long, across the diameter. Use a thin hack saw blade or equivalent. When you go to install it, it will compress and slide in. Tap it all the way until it is seated. Make sure to use a little sealer. Ive been doing it over 30 years...no problems!!!
