Re: Tech inspection question
[Re: Spode]
#554961
12/16/09 12:05 AM
12/16/09 12:05 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
You really don't need anything untill you go 11:50 or better. Sounds like you already have what you need just make sure you have a good helmet, your battery switch marked and not to much rubber hose on the fuel lines.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: DblOJoe]
#554964
12/16/09 12:13 AM
12/16/09 12:13 AM
Posts: 396 California, USA
Phil Saran
California, USA
You can go to www.nhra.com and read the rule book online also, or $10 + $3.50 S/H if you want a hard copy. Or if you are a NHRA member then the book is $7 + $3.50 S/H. You do not need a rear firewall if you have the stock rear seat AND the battery is enclosed in a metal battery box. On the rubber hose, you are only allowed a max of 12" total rubber hose in the whole fuel system so only connection points. The rest needs to be metal or braided fuel line or one of the other accepted fuel lines.
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#554965
12/16/09 12:15 AM
12/16/09 12:15 AM
Phil Saran
California, USA
How old is your helmet? Mine was manufactured in 2000 and is good until Jan 2012, so check into that, you may need to buy a new helmet.
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#554966
12/16/09 11:09 AM
12/16/09 11:09 AM
Posts: 242 Upland, California
Spode
Upland, California
Thanks for the responses. Looks like im good except for The wheel studs might be an issue. I currently have the extra deep style lugs similar to these. Will I need longer studs with a open nut on all 4 wheels. What are the options for the 5 on 4 bolt pattern wheels. Buy longer studs and have them pressed in? Do they make longer studs in the smaller diameter? Thanks again
[Re: topside]
#554968
12/16/09 12:24 PM
12/16/09 12:24 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If you decide to go with the Summit brand lug nuts be sure to run a tap through them before you use them.
DAMHIK
[Re: WILD BILL]
#554969
12/16/09 01:36 PM
12/16/09 01:36 PM
Posts: 1,087 Northeast, Arkansas
Dodgeman67
Northeast, Arkansas
Until you speed it up, I would take it to the track and go racing. They will tell you what you will need, but if nothing major is wrong they should let you run. Good luck and have fun.
[Re: Phil Saran]
#554971
12/16/09 03:41 PM
12/16/09 03:41 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
Yes, that is what is in the NHRA rule book.
Now in the IHRA rule book however, this is what they allow, and I quote,
"Rubber fuel line/hose is limited to 12" LENGTHS maximum for connection purposes only."
I have two places where I used rubber line, for connecting steel lines. About 18" total. It was at an IHRA track. I argued with the guy. He said 12" TOTAL. I said no, 12" lengthS are allowed. Didn't say how many 12" lengths a guy could use. I wasn't being a dink about it, but I wanted to race. He let me race.
Just a different way it's worded I guess , but it means two totally different things.
codfish
