Re: Bigger tie rod ends for 71-74 B-body?
[Re: Spanky]
#554606
12/15/09 07:46 PM
12/15/09 07:46 PM
Posts: 22,696 Bitopia
jcc
Bitopia
For the nth time, Why? Nobody has ever shown to my knowledge any emperical data to indicate how much less distortion is achieved with the larger 11/16" TR. Unless your main interest is hitting potholes, and curbs repeatedly and hard. The forces on a cornering wheel are mainly thru the ball joints anyway, the TR mainly see steering wheel correction inputs. If you think 11/16" is such a plus, why not say use 3/4" or larger then? And for reference have you ever seen what the Mustang 5.0 guys use for bump steer correction, although thousands are in use, and relative to a mopar 9/16 TR, a real IMO joke. Regardless, I bet you use 11/16" TR.
[Re: RokketRide]
#554608
12/15/09 08:17 PM
12/15/09 08:17 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Running beefier parts designed for bigger heavier cars on a smaller lighter car is the essence of hot rodding.
If they require replacement anyway and they cost the same, why not make the switch?
I agree, the larger ones are on my car..
[Re: Andrewh]
#554610
12/15/09 08:59 PM
12/15/09 08:59 PM
Posts: 21,832 Kirkland, Washington
Pacnorthcuda
look at it this way...Mopar decided that the larger, heavier C-bodys needed them, presumably due to the larger, heavier forces acting upon the steering components. Since we, as enthusiasts, are likely to drive our A/B/E's harder than average its very conceivable that our steering systems would need to endure forces similar to that of the c-bodys. And the centerlinks, pitman and idlers are built very beefy--the tie rods look wimpy in comparison. Some people even weld up the splits for added strength. Its not rocket science.
[Re: AndyF]
#554613
12/15/09 11:11 PM
12/15/09 11:11 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
So beefier tie rods, what about torsion bars. I see some advertised. Worth the upgrade ? What about Bondo Bob's new aluminum parts? I hope he chimes in.. Love his stuff. http://www.bobsprofab.com/
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: RokketRide]
#554614
12/16/09 12:32 AM
12/16/09 12:32 AM
jcc
Bitopia
Because with that line of thinking, we would all be driving 10 ton hot rod trucks. You only go heavier when you break something that isn't strong enough or you have a real need.
My Hot rod thinking is you use the lightest component to get the job done.
I'll repeat, TR do not transmit cornering forces, they transmit steering wheel generated imputs.
ON the way home I mulled over the components that are part of the chain of steering compliance. I have no testing to back up any of the following, except seat of the pants analysis. It also seems like no one else has any either.
On a typical performance aggressively driven mopar, with decent non OEM tires, I would guess the following, 70% of the steering compliance/lag/flex is simplely in the tires, 10% is in the rubber suspension bushings, 10% is in frame/chassis, the last 10% is maybe equally divided between the rim, the play in the bearings, the hub, the spindle, the LCA arm, the UCA, the TR, the TR adjuster, the drag link, the pitman arm, the steering gear box, the steering shalf, the mounting of the gear box and a few I likely forgot. If you divided those 15 equally for arguments sake, that's approx .66% that each accounts for overall flex. So if say a 11/16" TR ( which weighs 2x? as much), has a 50% (?)stiffer design, your improvement is .33% overall? OK GIGO, but really, what are you really gaining here? Adding 4 psi to you tires will get you way more then that
[Re: RokketRide]
#554618
12/16/09 01:29 PM
12/16/09 01:29 PM
jcc
Bitopia
Fair question, but my main point was again "why", its not so much about weight, which is equal to a 1/4 pounder, but the guess still remains, it's still only a .33% improvement. I may have an agenda in that my first resto mod many years ago I bought the 11/16" Tr, because that was the "hot" set-up, and then I asked my myself for many years, why exactly did I do that, I try to hear/understand other opinions/reasons, and then make thought out decisions, this choice of TR I could never justify. Does it hurt anything, not really, does it make many feel warm and fuzzy, I guess. Does it make sense, not to me, but then following the herd has never been my forte.
