Re: 4-speed manual question
[Re: TMBOOTS]
#553628
12/14/09 01:10 PM
12/14/09 01:10 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
It is normal to have some play in the input shaft. Is it lateral play or thrust ( in and out)? The shaft is supported by a ball bearing in the middle, a pocket bearing ( needles ) at the rear, and the pilot bushing/bearing in the back of the crank. Pay particular attention the the pilot to make certain it is in good shape and properly lubed upon reinstall. Is your vibration related to engine RPM, vehicle speed, or load?
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: zzyzxpat]
#553629
12/14/09 03:32 PM
12/14/09 03:32 PM
Posts: 227 upstate NY 12839
TMBOOTS
upstate NY 12839
It has some lateral play- thrust seems ok I would have to say engine RPM 2-3000 I will be installing a fresh 383 when my builder finishes the rebuild. I most likely will install a new tubular k-frame from CAP as the car was a slant 6 converted by welding in mounts, hoping proper engine alignment will solve some issues. THANKS for the info!!
[Re: TMBOOTS]
#553630
12/14/09 06:45 PM
12/14/09 06:45 PM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
Do yourself a favor and research CAP and customer feedback..........
[Re: Jim_Lusk]
#553631
12/14/09 07:36 PM
12/14/09 07:36 PM
TMBOOTS
upstate NY 12839
I couldn't find customer feedback on my search.Should I check out other suppliers?
[Re: TMBOOTS]
#553632
12/14/09 07:38 PM
12/14/09 07:38 PM
Jim_Lusk
Fresno, CA
I would - OR - if this is just an engine swap go with Schumacher mounts.
