Freeze plug seeping, What would you do? #552795
12/13/09 05:23 PM
12/13/09 05:23 PM
cataclysm80 Offline OP
Hello, I've got a freeze plug on my girlfriends 2000 Dodge Neon that has been seeping a little antifreeze out. It loses about a quart of antifreeze every 3000 miles.
It's pretty tough to get to in a neon. I'd probably have to take off the exhaust manifold & the passenger side CV axle. I was able to get my hand up in there and push on it. It feels solid, didn't push out, but still leaks.
The car just passed 100,000 miles and sometimes knocks just a little on a cold morning start.
What would you do?
Just add antifreeze every oil change until the engine wears out and needs rebuilt, or fix the freeze plug now, or other?
Can it be fixed without pulling the engine?
Tav
Re: Freeze plug seeping, What would you do? [Re: cataclysm80] #552796
12/13/09 05:37 PM
12/13/09 05:37 PM
abodyman Offline
super street
abodyman  Offline
super street
How well do You like Your girlfriend?
I didnt know it ever got cold in Florida!
The best thing to do, would be relace it, but its a big pain.
May as well flush out the cooling system while Your at it. To see if any more are rusted out.
Anyway, it will only get worse.
If things are real serious between You 2, then pull the motor and replace ALL of them.
You could try one of those rubber plugs that expand when You tighten them...But You still have to get the old freeze plug out and clean up the hole so the new rubber one will seal properly.
Now...My idiot brother actually SWEARS by taking egg whites and adding them to your radiator and then starting the car up till its warmed up...
I asked him one time, do You add salt and pepper with that? He didnt think it was funny
Re: Freeze plug seeping, What would you do? [Re: abodyman] #552797
12/13/09 05:42 PM
12/13/09 05:42 PM
actually people (including myself) have stopped minor coolant leaks with pepper
Re: Freeze plug seeping, What would you do? [Re: RapidRobert] #552798
12/13/09 05:44 PM
12/13/09 05:44 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
you could try an epoxy fix. JB Weld.
Re: Freeze plug seeping, What would you do? [Re: Pacnorthcuda] #552799
12/13/09 05:58 PM
12/13/09 05:58 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Find a new girlfriend...
Re: Freeze plug seeping, What would you do? [Re: 1_WILD_RT] #552800
12/13/09 11:44 PM
12/13/09 11:44 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
get the rotted plug out before it lets loose and over-heats and ruins the motor. Then clean the hole and use an expandable rubber plug or use a block heater plug if there is room inside the water jacket for the heater probe. That would be the easy way. Pull the engine, replace them all and flush the old crap out of the cooling system, fill with good antifreeze. that would be the correct way to do it, but not the easy way.
DRIVE EM, DONT HIDE EM.
Re: Freeze plug seeping, What would you do? [Re: Pacnorthcuda] #552801
12/14/09 06:12 AM
12/14/09 06:12 AM
BDW Offline
BDW  Offline
For a quick patch, since you mentioned you could get your hand to the spot.
Depends on how long you'll be with her?
Re: Freeze plug seeping, What would you do? [Re: BDW] #552802
12/14/09 09:47 AM
12/14/09 09:47 AM
NJ
440challenger Offline
NJ
drain the anti freeze and block, clean the freeze plug and surrounding area really well. Jb it up
Re: Freeze plug seeping, What would you do? [Re: 440challenger] #552803
12/14/09 12:24 PM
12/14/09 12:24 PM
P
Paul_Fancsali Offline
P
If you can spray down with brake clean and silicone seal it period make sure it sets up before you run it and if you can drain coolant before you do it below the freeze plug
Re: Freeze plug seeping, What would you do? [Re: RapidRobert] #552804
12/14/09 09:05 PM
12/14/09 09:05 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I'm with you on the pepper.About 2 tablespoons stopped the seeping head gasket on my old Buick Century 2.2 liter 4 cyl. Reapply as needed.
Re: Freeze plug seeping, What would you do? [Re: 67_Satellite] #552805
12/14/09 09:19 PM
12/14/09 09:19 PM
Jax, Florida
1976duster Offline
1976duster  Offline
Jax, Florida
K&W Engine Block Sealent!
Re: Freeze plug seeping, What would you do? [Re: 1976duster] #552806
12/14/09 10:00 PM
12/14/09 10:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
fix it right the 1st time, now before it becomes a bigger issue.
Re: Freeze plug seeping, What would you do? [Re: gtx6970] #552807
12/14/09 10:23 PM
12/14/09 10:23 PM
Walmart parking lot
yorker Offline
Drugs are bad
yorker  Offline
Drugs are bad
Walmart parking lot
My 97 Ram has had a slight leak at a freeze plug since I bought it 3 years ago. I have to fill the resivor and a little in the rad. about once a month.
It has never got worse. I have not fixed it.
Now I do not think mine is related to rust as I think the ccoolant system had been maintained.
If yoours is rusting, it may get worse.
I had a reputable garage tell me jb weld should work.
This belongs in the tech section
( SHONEN KNIFE ) MAKING THE WORLD A BETTER PLACE. ONE SONG, ONE CONCERT AT A TIME FOR OVER 36 YEARS!!
https://www.youtube.com/user/SHONENKNIFETV
Re: Freeze plug seeping, What would you do? [Re: yorker] #552808
12/14/09 11:00 PM
12/14/09 11:00 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
Get up Saturday morning, pull the engine, install core plugs, timing belt, water pump, any leaking gaskets or seals, clean and paint engine, it's running and ready Saturday night.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: Freeze plug seeping, What would you do? [Re: GTX70sixpack] #552809
12/14/09 11:30 PM
12/14/09 11:30 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Heck yeah, Just make sure she isn't like my last girlfriend who was boinking every other guy in town while I was keeping her car going for her......
Re: Freeze plug seeping, What would you do? [Re: minivan] #552810
12/14/09 11:37 PM
12/14/09 11:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Reason I liked my answer best...
"Find a new girlfriend..."
Re: Freeze plug seeping, What would you do? [Re: RapidRobert] #552811
12/15/09 09:45 AM
12/15/09 09:45 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I have stopped minor coolant leaks with pepper also. I used "coarse ground pepper" as the regular seems to be too fine. Leak was stopped for as long as I needed.
Pepper doesn't seem to have any adverse effects on the cooling system like other sealers do.
If it's already knocking on cold start up the motor isn't in the best of shape anyway.
Re: Freeze plug seeping, What would you do? [Re: abodyman] #552812
12/15/09 11:41 AM
12/15/09 11:41 AM
Sarasota, Fl
siggie30 Offline
siggie30  Offline
Sarasota, Fl
You know, I thought I had the only dumb------ brother that would put an egg into the coolant system. He put 3 in the truck I gave him (97' tacoma) and it plugged up the heater box and the head gasket, eventually leading to a cracked head. I bought it off of him for $200 and fixed it for about $400 total (including a used head). Been driving it (again) ever since. The pepper trick is a temporary fix only and should be used for "getting home". I would suggest that you take the time to do a proper repair and replace the plug unless your girlfriend is not worth your time, but I imagine that you could trade off the next argument with the repair.
I don't even have 1/2 lift, but the other 1/2 is nitroused.
Re: Freeze plug seeping, What would you do? [Re: cataclysm80] #552813
12/15/09 04:27 PM
12/15/09 04:27 PM
Az
Crizila Offline
Crizila  Offline
Az
What would you do?
Tav
Give it to the local chruch and claim it as a tax deduction.
Fastest 300
Re: Freeze plug seeping, What would you do? [Re: gtx6970] #552814
01/27/10 01:50 AM
01/27/10 01:50 AM
Thanks for all the suggestions guys. I haven't figured out when yet, but it looks like I'll be replacing the freeze plug to fix it right. I proposed Friday evening while we were on a four day weekend in Key West.
Tav
