Shackle Angle? #552723
12/13/09 02:59 PM
12/13/09 02:59 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I'm working on mini tubbing on my Dart and have the spring boxes welded in. I checked the shackle angle yeaterday, using the holes that are in the frame, it is at 20*, about 1 3/16" top to the front. I also marked through the factory hanger, this would give it about 5/16" top to the front. This was checked with the cars weight on the spring.
Will 5/16" be enough?
Can the tubes that go through the frame be bought? If not I'll cut the old ones out of the factory brackets.
Thanks, Justin
Re: Shackle Angle? [Re: justinp61] #552724
12/13/09 03:18 PM
12/13/09 03:18 PM
gregsdart Offline
gregsdart  Offline
You can make your own tubes for the upper shackle mount if you need to. I am assuming you have a welder, grinder, drill and a cutoff saw or similar, or a buddy that can help you out.
A piece of tubing, a couple of washers or a piece of plate you can drill a hole in and weld to the sub frame on either side is all you need. Shoot for 45 degrees, at rest. That will make the rear suspension very responsive. A little extra shackle length will also increase rise, if you want to increase the total body seperation under power. I made mine out of 1/2 by 2 inch flat stock, with a couple of extra holes to see what I liked best.
Re: Shackle Angle? [Re: gregsdart] #552725
12/13/09 07:11 PM
12/13/09 07:11 PM
ky
68roadrunner Offline
ky
when i had springs on the runner, i had extra holes in the front to change ic height. did not get a confirm test with this. just an idea
