You can make your own tubes for the upper shackle mount if you need to. I am assuming you have a welder, grinder, drill and a cutoff saw or similar, or a buddy that can help you out.
A piece of tubing, a couple of washers or a piece of plate you can drill a hole in and weld to the sub frame on either side is all you need. Shoot for 45 degrees, at rest. That will make the rear suspension very responsive. A little extra shackle length will also increase rise, if you want to increase the total body seperation under power. I made mine out of 1/2 by 2 inch flat stock, with a couple of extra holes to see what I liked best.
