HEADS UP RACING CLASS (NATURALLY ASPIRATED) #552608
12/13/09 12:56 PM
12/13/09 12:56 PM
IL
acme383 Offline OP
acme383  Offline OP
IL
It's been a long time since Mopars had a real competitive heads up class since King of the Street. I know there have been other heads up racing out there, but never really caught on. This class would have an emphasis on LOW COST, since alot of cars would already fall into this category. Here are the rules.
1)3500# min weight(no weight breaks)
2)max cid 540(must use a STOCK BLOCK!!!)
3)must run INDY SR or 440-1 heads.
4)single carb on cast available intake(no sheet metal)(no E85 or Methanol)
5)stock frame rails(no front or back halves)
6)no wheelie bars
7)max tire as stamped on tire. 31x10.5W
8)max 4 foward gears. manual or auto.
9)stock appearing interior. no sheet metal.
10)stock appearing bodies. no ground effects or spoilers.
11)hood scoops ok. max height 10"
fastest 16 qualifiers.
Indy could sponsor for obvious reasons.
Anyone interested???
"Beating the competition with a stick is just automatic!"
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552609
12/13/09 01:40 PM
12/13/09 01:40 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
I'd ask Indy first.
'71 Duster
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552610
12/13/09 01:48 PM
12/13/09 01:48 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Heads up racing: Is the best way to run, but without limiting the horsepower or the size of the tire. Thnig is to put four categories, one for 8 seconds, one for 9 seconds, a 10 s and 11.
That way if you don't have the Money to run 8 seconds you can run 10 seconds. In every heads up start your car would have to keep low 10 seconds and you need to have a good reaction to win the category of 10 seconds because if you drop to 9 seconds, cars competing in nine seconds will be in nine seconds low and your 10 second car won”t have a chance. This way, you have four categories, four winners, each preparing his car and invest whatever they can, and include more cars the day of competition. That's how we race over here in Peru
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: Thackdaddy] #552611
12/13/09 01:53 PM
12/13/09 01:53 PM
IL
acme383 Offline OP
acme383  Offline OP
IL
I'd ask Indy first.
It's just a idea. just looking for interest.
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552612
12/13/09 01:58 PM
12/13/09 01:58 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
9.0s on a stock block...hope you figure in a lot of cleanup time at the track....
71 440-6 4spd & 69 Hemi 4spd
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: cbarracuda] #552613
12/13/09 01:58 PM
12/13/09 01:58 PM
IL
acme383 Offline OP
acme383  Offline OP
IL
I'm not suggesting an index class. Some of us like the idea of going as fast as possible with are given combos, but without spending boatloads of money to be competitve. This would promote an emphasis on tuning.
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552614
12/13/09 03:17 PM
12/13/09 03:17 PM
Az
Crizila Offline
Crizila  Offline
Az
Same thing as AHRA ET brackets of old.
Fastest 300
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: hemi_doug] #552615
12/13/09 04:40 PM
12/13/09 04:40 PM
IL
acme383 Offline OP
acme383  Offline OP
IL
That's what they make diapers for.
i know alot of cars running low nines with that combo. i'm sure with tuning and chassis setup, cars would eventually break 8.99 .NHRA probably never thought SS/AH cars would be running mid to low 8's!
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552616
12/13/09 05:04 PM
12/13/09 05:04 PM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
The power needed to move 3500lb car to low 9 high 8's would stress a stock block to the point of failure.Diaper or not,it's a safety issue.Same with wheelie bars.
I would not put myself in a position to grenade an engine and possibly injure myself or another racer.So No I would not be interested.My
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552617
12/13/09 05:08 PM
12/13/09 05:08 PM
Akron, Ohio
ProSport Online content
ProSport  Online Content
Akron, Ohio
Good luck with car count with all those rules. Why does the car have to weigh 3500pounds, why only Indy heads, why stock block, why...............
That's why I just goof off with my car, all these classes at different tracks with all the different rules.
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552618
12/13/09 05:18 PM
12/13/09 05:18 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Here are the rules.
6)no wheelie bars
Sorry, but I have to ask... does your car fit these rules EXACTLY, by some chance?
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: gillman34] #552619
12/13/09 05:20 PM
12/13/09 05:20 PM
IL
acme383 Offline OP
acme383  Offline OP
IL
let me correct myself. I was not saying the cars "should" run 9.0's, I meant that they probably would eventually run those numbers. i editted the post as not to confuse anyone. as far as the wheelie bar rule, NMCA prostock class has that rule as well and they are running low 8's on a smaller tire.
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552620
12/13/09 05:21 PM
12/13/09 05:21 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Nor are they running blocks casted in 1968.
Why would anybody want to build a engine for a class where the diaper is going to get tested regularly????
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: bigtimeauto] #552621
12/13/09 05:31 PM
12/13/09 05:31 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
First you said N/A only...there are hardly any 9.0 N/A 3500 pound mopars out there..I can only think of a handful that could run 8.90's at 3000 pounds???
10.0 n/a class maybe...
Good luck...
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: bigtimeauto] #552622
12/13/09 05:36 PM
12/13/09 05:36 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
'Problems that I see:
1) Limiting the heads to Indy products
2) The naturally aspirated thing would be a stretch.
3) The stock block thing is going to get rid of about 50% of the serious head count.
It would still be a very cool class they way you set it up, I just don't see that many cars that could compete given those stipulations (brand wise, especially).
If it was my race I'd set a weight limit for every general combo (n/a, turbo, SB N20, etc) and specify parts that connot be used (aka B1MC, 572-13, etc).
Cool idea!
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: bigtimeauto] #552623
12/13/09 05:37 PM
12/13/09 05:37 PM
IL
acme383 Offline OP
acme383  Offline OP
IL
not everyone has the money to buy an aftermarket block. plus it would be easier to regulate engine size. i think you are missing the point. alot of people are already running this combo right now. without having to spend any money. who knows, maybe the bump would be 9.50. it's just an idea i was talking over with some friends. I know alot of people are bored with bracket racing, and have grudge racing between friends that makes you go faster without spending a ton of dough. that's all!
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552624
12/13/09 05:41 PM
12/13/09 05:41 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
If you don't have the money to buy a aftermarket block you don't have the money to go heads up racing.
Can't you buy iron blocks for around 2500? You will have 12-1500 in a stock block thats looking for a place to break anyway.
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552625
12/13/09 05:55 PM
12/13/09 05:55 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
We've been low 9.3x's with a 3500lb car and a stock block, not a big deal. Dan's trying to throw out ideas for a budget, yet heads up class. He's NOT saying you have to run any certain ET, you could run 12's for all anyone cares. Stock block, aluminum heads, 3500#(or heavier)and a 10.5 tire would describe A LOT of mopar B body cars out there.....
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: acme383] #552626
12/13/09 05:56 PM
12/13/09 05:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
6)no wheelie bars
You sure are restricting the field with just Indy
heads... why not any head with a bonus if you do
run a Indy head.... I dont come close to fitting
in but its a suggestion
Re: HEADS UP RACING CLASS (NATURALLY ASPIRATED) [Re: Jeremiah] #552627
12/13/09 05:57 PM
12/13/09 05:57 PM
IL
acme383 Offline OP
acme383  Offline OP
IL
Cool idea!
the reason for the Indy heads, is horsepower output. bottom line. 440-1 heads flow @ 390 give or take. therefore it limits the horspower output.
weight breaks get too complicated. some cars will need to add weight. it eliminates the cost of lightweight componenets to lighten up the cars for their given weight break. just simplier. please forget the projected et's(example 9.0). i was merely throwing out a number.
