Re: 528 head selection?
[Re: 68roadrunner]
#552238
12/12/09 08:12 PM
12/12/09 08:12 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
b1 not as familiar with the different b1 products
Give Scott a call or send him a PM b1headman
He'll be more than happy to explain the differences and set suggest the right B1 for your application. Tell him I sent ya,
[Re: 68roadrunner]
#552239
12/12/09 09:14 PM
12/12/09 09:14 PM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A lot depends on how high you are willing to spin it. My 528 with 440-1 ported heads pulled max power from 6600 rpm to 7000 rpm, I shift at 7200. I wouldn't waste the time with the 572-13 unless you get a smoking deal on them, as they don't produce that much more power than a well done up 440-1. Then it would be time to move to a b1, and if you are going that far, spend the fesw extra $$ and get the Moved Centerline version and you can really build some steam. Those are for a 4.500 bore. You might be revving it to 7600 to 7800 rpm or more, but the potential for 1050 + hp is there.
[Re: gregsdart]
#552240
12/12/09 09:25 PM
12/12/09 09:25 PM
Posts: 877 ky
68roadrunner
ky
thanks bill and greg spinning the motor wouldn't bother me at all, as it will have good parts in it. thanks for the heads up on the 572-13, i did not know they was not that much better. i have the 499 stock block in it now , and want to start buying up parts to replace it with . i thought i would go to the 528 to carry the extra weight of the aftermarket block let me know what you think
[Re: sixpakdodge]
#552243
12/12/09 11:30 PM
12/12/09 11:30 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
What would be the Bore size on this particular 528 combo? I will assume a 4.5 bore with a 4.15 crank. The real question needs to be answered is how much power are you looking to make? The 440-1 will make 800+ in a all out deal easy. Any way you slice it a B1 Original on that same motor will make another 75+hp more. The B1 stuff is a little extra money for the bare heads, or assembled...After that I see very little if any price diff, A jesel or T&D rocker system will cost you about the same. The port work will cost you about the same, pistons willbe about the same...You might see some additional cost on valves, some like the titanium valves in the B1 stuff due to the over all diameter and length..Im sure there is plenty of guys running run of the mill stainless valves though. Other things to consider. The Indy heads have a better choice of intakes, with B1 heads you have two choices, the cast B1 intake which is a nice piece, or a sheet metal custom intake. I would go with the B1 stuff for the simple fact of way more power potential. It has better resale value IMO also. If your looking to save some money but wanting to go with the B1 stuff, you dont need full tilt port work to make 800+ hp with these heads..You do with the Indy stuff. I would imagine it would cost a extra $500 for the B1 package over a similar Indy package. maybe a hair more. Thats not that bad of a deal for 75-100+ Hp IMO. Fact is I built a engine similar to this with Indy stuff, in the end I wished I went with B1 stuff. When you see people upgrading and they are running a Indy Package..they are going with B1 stuff for a reason.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: sixpakdodge]
#552244
12/13/09 09:17 AM
12/13/09 09:17 AM
Posts: 877 ky
68roadrunner
ky
I'm using the -1's on my 528 build, haven't picked a cam yet.
what size runners and valves did you go with
[Re: Bob_Coomer]
#552245
12/13/09 09:36 AM
12/13/09 09:36 AM
Posts: 877 ky
68roadrunner
ky
greg no i don't have a crank or any perts at this time. just trying to make a game plan. sure i could build a larger engine, but the dragster runs 5.04-5.08 with the 499. add 50 -100lbs for the aftermarket block. maybe a 528 will go the same or maybe 4.9s. i like the times it is running, never a traction issue,only a few quicker than me, and besides i am not got alot of passes in it, i need more seat time. bob thanks alot yes i was thinking 4.50X4.150 power level? 5.05 at 1850= 750ish ? 4.95 at 1950lbs= ??? maybe 100 more hp, i am not sure,i have not calculated it, $500 for that hp is a bargain,the only reason for me to use -1s is i have 2 sets already,if i want to take an engine apart that is. the moved centerline heads must cost alot more? i assume the rpm range would be higher with the b1s
[Re: supercomp]
#552249
12/13/09 12:29 PM
12/13/09 12:29 PM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
In a light drag only car where you're not concerned about needing any torque advantage below 4500rpm the B1 is the best (affordable....I'm excluding the Predator) choice. Most B1's won't flow any better than any other wedge below ~.500-.550 lift (despite much larger ports and valves) so they need big cams and compresion to show their stuff....with the combo you describe it's gonna be the best choice, hands down. What supercomp said is very valid about the piston....but it sounds like ytou're upgrading the shortblock anyway.....you can always sell the -1's (there' always a good resale market for them....especially worked ones with proven performance) to offset the cost.
[Re: B1Fish540]
#552250
12/13/09 12:34 PM
12/13/09 12:34 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I have the 528 cu in engine with the 4.50 bore 6.570 BME aluminum rods 4.15 crank with the 572-13 heads with a tunnel ram & Ron's Terminators in my dragster. I am very happy with it.I have never had a set of B1 heads so I can not say which is the best.My engine came from Indy and the dyno sheet says 936 hp @ 7200 RPM with one 1095 King Demon sq jetted at 93.I have been told Indy fudges on thier dyno sheets. I don't know about that either But I will be happy to share the info on this engine(I have the build sheet from Indy)with you or anyone else if it will be of any help.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: supercomp]
#552252
12/13/09 02:05 PM
12/13/09 02:05 PM
Posts: 877 ky
68roadrunner
ky
There is nothing fancy in ours. just a callies crank, manley 6.535 rods and je 1.365 ch pistons (heavy 586 grams). a .752 lift cam with 280/283 dur. 112 lsa and 1050 dom dynoed with a thottle stop under the carb. a idiot could build this motor. in fact one did, me.
is this the 500" what kind of heads and et does it run
[Re: 68roadrunner]
#552254
12/13/09 03:34 PM
12/13/09 03:34 PM
gregsdart
Ok, sounds like you want to pick up a tenth, offset the block weight as well. That is about another 70 hp over what you have. Another idea would be to build a moderate size shortblock, with a large bore and short stroke. Anything from 500 to 528 will work, preferably the smaller of the two, to keep starting line torque similar to what you have. Set the motor up with heads that will build the power you want with a bit more rpm to get the extra power you want. A 3.9 inch stroke with a 4.500 bore gives you a 496 cube motor that will have moderate torque like you now have, breath extremely well with the 440-1 heads on it, and make very good power peaking roughly at 7500 rpm. You should be able to reach your goals, have a very consistent car, and yet go faster still. You didn't specify which heads you currently run though. Are you running fully ported 440-1 heads now ?
[Re: 68roadrunner]
#552255
12/13/09 05:55 PM
12/13/09 05:55 PM
Posts: 3,441 Mo.
supercomp
Mo.
They are B1 originals on a stock 400 block. 4.375 bore by 4.150 stroke. Runs 1.09 60ft, 4.90s 1/8, high 7.80s 1/4, 171mph. Weighs 1940 lbs. Shift at 6800, end around 7100. 4.10 gear 33.5 x 17 x 16 on beadlocs. Over 500 passes without pulling heads or pan. Replaced 2 intake lifters caught early with a little to much lash.
