Standard radiator width in '69 and '70 for.. #552129
12/12/09 05:25 PM
12/12/09 05:25 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
a 440 equipped b-body with a 727, 3.23 and no a/c....
Troy
Houston Mopar Connection Club
Re: Standard radiator width in '69 and '70 for... [Re: hemi68charger] #552130
12/12/09 05:44 PM
12/12/09 05:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
22"
Re: Standard radiator width in '69 and '70 for... [Re: 1_WILD_RT] #552131
12/12/09 07:15 PM
12/12/09 07:15 PM
Houston, Tx
Houston, Tx
22"
Are you sure?
Troy
Re: Standard radiator width in '69 and '70 for... [Re: hemi68charger] #552132
12/12/09 07:42 PM
12/12/09 07:42 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Well they didn't use the 18.5"... & the 26" was commonly used but without any option caising the 26" upgrade the 22" was standard.. So what have you got that proves this wrong....
Re: Standard radiator width in '69 and '70 for... [Re: hemi68charger] #552133
12/12/09 10:23 PM
12/12/09 10:23 PM
o'fallon, MO
Brian_E Offline
Brian_E  Offline
o'fallon, MO
no a/c and the radiator is small, 22 inch is correct. unbelievable but true. i alwasy thought it was a 26 some thing to max out the cool for a big block, but its small in comparison to a/c cars, max cool option and other ordered options. opinion.
Re: Standard radiator width in '69 and '70 for... [Re: Brian_E] #552134
12/12/09 10:39 PM
12/12/09 10:39 PM
Houston, Tx
Houston, Tx
Well guys.... I was aiming at Daytonas and Superbirds... I thought the base rear gear for any of them would have been a 3.23 gear for a 727. But, after doing some research with some buddies of mine, it seems pretty much every Daytona had an axle package, hence a 26". There's one "example" of a Daytona with a 440 727 and supposedly a 3.23 and a vintage picture that did show a 22" radiator. Also, all Superbirds were to be made standard with an axle package (3.55 or 3.54), hence always getting a 26" rad.
So, whereas the Superbird by default would have had it by design, the Daytonas seemed to have them by "chance" design, if it can be worded as such. The A13 Superbird code calls for an axle package, but the 69 1/2 Daytona A11 doesn't require an axle package.
Oh well, thought I was on to something... Sooo, is there ANY Daytonas out there with a 440, 727, 3.23 combo? And, if so, is your car equipped with a 22" or 26". I thought by the restricted air flow from the nose, the 26" would be mandatory.
Also, my digging deeper turned the page on me.
Cheers,
Troy
Troy
Re: Standard radiator width in '69 and '70 for... [Re: hemi68charger] #552135
12/13/09 11:13 AM
12/13/09 11:13 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
Did the 22" and 26" use the same size
cut-out in the core support?
Re: Standard radiator width in '69 and '70 for... [Re: demonH1B] #552136
12/13/09 11:16 AM
12/13/09 11:16 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I thought all wingcars received max cooling with the wingcar pkg. regardless of rear gear
Re: Standard radiator width in '69 and '70 for... [Re: gtx6970] #552137
12/13/09 12:14 PM
12/13/09 12:14 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
All "wingcars" have an axle package & no factory A/C; Charger 500s were STD with 22" radiators - axle packages and/or A/C were OPTIONS.
Re: Standard radiator width in '69 and '70 for... [Re: 6bblgt] #552138
12/13/09 12:21 PM
12/13/09 12:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm not 100 % sure but the Petty Blue bird formerly owned by a friend of mine ( now owned by Tim Welborn) had a 2.76 suregrip gear.My question, is this still considered an axle pkg
Re: Standard radiator width in '69 and '70 for... [Re: gtx6970] #552139
12/13/09 12:34 PM
12/13/09 12:34 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
2.76s weren't an axle package, just an OPTIONAL ratio.
Superbirds with automatics had 3.55s & 8-3/4" ONLY
Superbirds with 4-speeds had 3.54s & DANA 60s ONLY
I'd "assume" someone could've put in 2.76s in an attempt for gas mileage.
I think the 4" difference in the core support is all to the passenger side.
Re: Standard radiator width in '69 and '70 for... [Re: 6bblgt] #552140
12/13/09 02:00 PM
12/13/09 02:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Both sides are different on both B & E bodies...
Re: Standard radiator width in '69 and '70 for... [Re: gtx6970] #552141
12/13/09 03:12 PM
12/13/09 03:12 PM
Houston, Tx
Houston, Tx
Superbirds were all destined, but option code breakdown, to have an axle package. So, by default, all would have to have a 26" radiator. As far as teh Daytona goes, the A11 option did not specify an axle package. I think it just turned out that most, if not all but one "known" units, came down the assemble line with an axle package. Now, for me, it begs the question..
Did the engineers make sure the Daytona came with an axle package, thereby getting a 26" radiator? Or, was it fate?
The A13 Superbird was to get an axle package. So, what that because they didn't want any with 3.23's or did they really want all to come with 26" radiators and to facilitate this, they mandated an axle package.
A13 Superbird Package
Aerodynamic Front End treatment, hideaway headlights, fender vents, Vinyl Roof, Hood Tie-down Pins, Power Steering, Power-Disc Brakes, A33 w/D21 or A36 w/D32, 440 44bl, Special windshield moldings, Goodyear polyglas raised white letter tires, larger "PLYMOUTH" logo on rear quarters, special order front and rear spoiler to name the majority of them
A11 XX29 Charger Daytona
Aerodynamic Front End treatment, Special windshield mouldings, fender vents, front and rear spoiler, hideaway headlights, HD 11" Drum brakes, Bucket seats, A727, 440 4bbl, HD battery, Electric clock, Bumper guards - RR, HEMI Suspension, Red streak tires, Daytona Bumblebee Stripe, Special Order
No where on A11 does it mention axle package..
Troy
Troy
Re: Standard radiator width in '69 and '70 for... [Re: hemi68charger] #552142
12/13/09 03:35 PM
12/13/09 03:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
My buddies Superbird 440-4 Auto came with a 3.54 geared Dana..
Re: Standard radiator width in '69 and '70 for... [Re: 1_WILD_RT] #552143
12/13/09 04:00 PM
12/13/09 04:00 PM
Houston, Tx
Houston, Tx
That's a first.. I've never heard of a Dana equipped auto car unless it was a 4.10 (which wasn't available on Superbirds)
I have a friend here in Houston as well with a 440 4bbl A727 with a Dana. He thought it was original since the previous owner told him it was. After looking at the broadcast sheet, I showed him where it came with a 3.55:1 8.75 rear originally....
Troy
Troy
Re: Standard radiator width in '69 and '70 for... [Re: hemi68charger] #552144
12/13/09 04:11 PM
12/13/09 04:11 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Troy
My buddies is coded as a 3.55 8.75 also.. But he's the second owner & has known of the bird since new it left the factory this way.. Your buddies might have come that way too...
Re: Standard radiator width in '69 and '70 for... [Re: 1_WILD_RT] #552145
12/13/09 05:17 PM
12/13/09 05:17 PM
Houston, Tx
Houston, Tx
Troy
With regards to this and MaMopar, anything's possible.
Troy
