Re: Old Crane Hemi cam grinds... [Re: mgpanos] #551988
12/16/09 02:40 PM
12/16/09 02:40 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
The R286/500-4 was commonly used in the Super Stock Hemis in the late 70's and maybe early 80's. The R290/446-4 was the first popular Crane grind for the Pro Stock-style Hemis, but was a killer on valve springs. It was replaced by the R296/4778-8 which wasn't quite so hard on springs even with more lift. I have never heard of the R285/410-8 but suspect it was for the heavier Super Stock cars.
Mark
Your right...the R290 was the first really big cam used in early HEMI pro/stockers and it found it's way over to super/stock.
I've been using that cam for about 30 years and still love it..
My newest HEMI stroker(478) is using it and the motor will be going in my "SILVER BULLIT" clone.
The cam specs very from make to make. So the cam card showing it over 700lift is wrong for a HEMI. Get an early('71-'74) Crane Cams catalog!
Fred
Post deleted by Defbob [Re: 52savoy] #551989
12/16/09 02:49 PM
12/16/09 02:49 PM
Re: Old Crane Hemi cam grinds... #551990
12/16/09 02:54 PM
12/16/09 02:54 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
one Fred to another....
The chart "deaks" posted might be for a Ford or Chevy..(different makes). I have a '73 catalog and it shows different cam specs depending on the make of engine.
Re: Old Crane Hemi cam grinds... #551991
12/16/09 03:08 PM
12/16/09 03:08 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Fred
The " Basic " Crane grind number system would be :
R-288/4714-2S-10
The Prefix would indicate the type of lifter.(in this example R )
H = hyd flat tappet
S = Solid flat tappet
R = Roller Tappet
HR = Hyd Roller
IR = Inverted Ramp Mechanical Roller
TR = Track Mechanical Roller
ect ect
The second grouping is the duration @ .050.( in this example 288 )
The 3rd is the INTAKE lobe lift.( In this example .4714 )
The - 2 after the intake lobe lift would mean the ex is 10 deg longer dur @ .050.
-2S , 2S1 , 2S2 indicated more Ex duration but not exactly 10 deg more.
-2R would mean 10 deg less exhaust dur.
-2SR means less Ex dur but not exactly 10 deg.
The last set of numbers is the LSA when you add 100 deg to it.( in this case the 10 plus 100 = 110 LSA.
Have no idea what the S stood for. Maybe the S meant Special,
Well that would mean this cam could possibly have a 104 LSA not a 114? LOL....My brain hurts now
Re: Old Crane Hemi cam grinds... [Re: Bob_Coomer] #551992
12/16/09 04:15 PM
12/16/09 04:15 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
You could be right, although i was looking for info on the R280 and 286 at the time and the R280 specs tallied with my R280 measurements.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Old Crane Hemi cam grinds... [Re: deaks] #551993
12/16/09 04:34 PM
12/16/09 04:34 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
I feel your pain!
I 'inherited' a stack of Hemi cams with little info...
Trying to figure the specs on this one:
Re: Old Crane Hemi cam grinds... [Re: HemiDave] #551994
12/17/09 11:20 PM
12/17/09 11:20 PM
SLC, Utah
mgpanos Offline
mgpanos  Offline
SLC, Utah
Wow, I think that is an old Racer Brown setup you have there! Racer Brown was a popular choice in the early Hemi Pro Stockers, but the narrow lobe probably limited the spring pressure due to high loads at the roller. I used to have some of the Racer Brown info but have misplaced it long ago. Sorry.
