WHERE IS RAD FAN RELAY ON 2001 CHRY CARAVAN? #551699
12/12/09 02:09 PM
12/12/09 02:09 PM
USA
540DUSTER Offline OP
USA
anybody on the board that can tell me where to find relay? It has two fans and none are working,40 amp fuse is good. HELP PLEASE!!!!!
Re: WHERE IS RAD FAN RELAY ON 2001 CHRY CARAVAN? [Re: 540DUSTER] #551700
12/12/09 04:06 PM
12/12/09 04:06 PM
Raleigh, NC
Y
Youngblood Offline
Youngblood  Offline
Y
Raleigh, NC
IF IT IS 3.3 LITER, LOOK RIGHT IN FRONT OF CONDENSER, RIGHT BEHIND GRILLE
Re: WHERE IS RAD FAN RELAY ON 2001 CHRY CARAVAN? [Re: Youngblood] #551701
12/12/09 07:22 PM
12/12/09 07:22 PM
USA
USA
Thanks Youngblood,We found the relay and it tested OK,now we can't find the coolant senser.The relay isn't getting any juice when the engine is hot.Can you help me out again.THANKS. by the way it is a 3.3 What does the ecm have to do with the fans? Man I hate these new cars.It should be against the law for an engine to have any more than 10 wires going to it.
Re: WHERE IS RAD FAN RELAY ON 2001 CHRY CARAVAN? [Re: 540DUSTER] #551702
12/12/09 08:24 PM
12/12/09 08:24 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
The Fan controller is mounted on the left frame rail near the radiator.Check the fuse box for corrosion.
Re: WHERE IS RAD FAN RELAY ON 2001 CHRY CARAVAN? [Re: moretoys] #551703
12/12/09 09:02 PM
12/12/09 09:02 PM
USA
USA
Thanks moretoys,I didn't know about the controller.I'll check that out.The fuse was good and clean.DO both fans run at the same time or only when the ac is on?
Re: WHERE IS RAD FAN RELAY ON 2001 CHRY CARAVAN? [Re: 540DUSTER] #551704
12/12/09 09:12 PM
12/12/09 09:12 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Re check the relay(LF frame rail)they go bad alot. If you do replace it make sure it is securely mount as this how it dissipates heat.
Re: WHERE IS RAD FAN RELAY ON 2001 CHRY CARAVAN? [Re: SALEM1912] #551705
12/12/09 09:44 PM
12/12/09 09:44 PM
USA
USA
1912,the relay was in front of the rad and it was a weird looking thing with cooling fins sticking out of it.WE jumped it and the fans would run.In the morning we will check out the thing on the frame rail.Thanks again; will let you know what we find.
