Upper Ball joint socket question #551611
12/12/09 11:15 AM
12/12/09 11:15 AM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
I know there are 2 sizes of Ball joint sockets.
Ive just purchased the "Small" Ball joint socket,according to the seller.
http://cgi.ebay.com/ebaymotors/ws/eBayIS...IT#ht_500wt_980
What applications of vehicles will this fit?
Re: Upper Ball joint socket question [Re: SPWC] #551612
12/12/09 11:48 AM
12/12/09 11:48 AM
Andrewh Offline
Andrewh  Offline
there are actually 3.
small is for a-bodies before 70 something. Either 73 or 76 but can't remember when they changed to the bigger.
Med is for most other cars.
Large is for trucks.
Re: Upper Ball joint socket question [Re: SPWC] #551613
12/12/09 12:56 PM
12/12/09 12:56 PM
63-72 A bodies (maybe even earlier than that). Not sure if all '73 up A bodies went to the larger (B/E type) upper ball joint (& obviously needing the larger socket) or just the disc equipped ones.
Re: Upper Ball joint socket question [Re: RapidRobert] #551614
12/12/09 01:45 PM
12/12/09 01:45 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
My '73 swinger had big ball joint uca's with 10" drums and small bolt pattern. (/6 car)
I think when I say big ball joint I mean medium ball joint...
I think the 73 changeover was fuzzy for bolt pattern and brakes.
Re: Upper Ball joint socket question [Re: radar] #551615
12/12/09 09:35 PM
12/12/09 09:35 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
small socket is '72-earlier A-bodies, medium is '73-up A, All B and all E. Large is truck, van and C body. '73-6 A bodies with front drums had medium ball joints and small bolt pattern
Re: Upper Ball joint socket question [Re: 446acuda] #551616
12/13/09 12:43 AM
12/13/09 12:43 AM
Andrewh Offline
Andrewh  Offline
c bodies use the med size not the large.
imperials might use the large, but I don't know for sure.
I know c bodies did not.
