Re: Paint under vinyl top?
[Re: mopar 394]
#551575
12/13/09 03:10 PM
12/13/09 03:10 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Just paint it base clear with the rest of the car and rough it up with scotchbrite or fine sandpaper before installing the top.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#551576
12/13/09 03:27 PM
12/13/09 03:27 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I can't wait to see the post were a "Mopar" guy/gal paints the car inside and out, top to bottom, engine bay, trunk, jambs, underside, hardtop or vinyl roof car, regardless of what gets covered up/over with trim, upholstrey etc,etc with the same "stage" of paint .....I've been painting cars for 30 years,.....and I'm amazed at the "Mopar mismash" of painting panels off the car, different "stages" of paint used in jambs, engine bays, trunks.... .....I don't get it?,...is it a $$$ factor?
[Re: DAYCLONA]
#551577
12/13/09 03:33 PM
12/13/09 03:33 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Yeah, we're all really cheap.... Any paint under the vinyl top has to be better than what the factory did.. Just lay down a couple full wet coats so it's well sealed.... Paint it Pink, it'll be worth more..
[Re: DAYCLONA]
#551578
12/13/09 06:00 PM
12/13/09 06:00 PM
Posts: 1,572 Jacksonville Florida
elitecustombody
I'm with you on that one ,and I will probably never understand it either.
[Re: elitecustombody]
#551579
12/13/09 06:34 PM
12/13/09 06:34 PM
Posts: 129 waukon iowa
1hot68
waukon iowa
I personally would never do it that way,but I can understand why some of these guy do.
[Re: CJK440]
#551584
12/14/09 12:07 PM
12/14/09 12:07 PM
DPelletier
Why bother with the base, just clear right over the primer. Single stage without needing to get something else.
Well, that would certainly work, but I just figured it was simpler to tell them to paint the whole car without trying to treat certain areas differently.......your car; your choices - mine got painted EVERYWHERE in base/clear.
1974 'Cuda
[Re: DPelletier]
#551587
12/14/09 07:59 PM
12/14/09 07:59 PM
Posts: 571 Denver,NC
hemiheadNC
Denver,NC
....dont EVER use POR 15 under a v-top....
I'm lost in the 60's and DAMN proud of it.
[Re: 1_WILD_RT]
#551589
12/14/09 08:05 PM
12/14/09 08:05 PM
hemiheadNC
Denver,NC
...thanks, you're right....sorry, brain drain on Monday....
