Tie rod thru oil pan #551127
12/11/09 02:31 PM
12/11/09 02:31 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
The oil pans that have the tie rod passing thru them... is there any thing that can be done to the rod ends to make it easier to come apart? I would like more pan capacity, but don't want to have to beat the tie rods apart to pull engine or oil pan.
Thanks, Brian
Re: Tie rod thru oil pan [Re: '72CudaRacer] #551128
12/11/09 02:44 PM
12/11/09 02:44 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
It's the center link that goes through the pan and although I haven't used one, I don't see how you could make it easier to come apart. Everything that bolts to it is a tapered press fit.
A tie rod seperating tool might make the job easier.
Re: Tie rod thru oil pan [Re: WILD BILL] #551129
12/11/09 02:56 PM
12/11/09 02:56 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
MR2 chassis sells a bushing that can go in there to make it so the sterring link drops on and off. Most of the Superstock guys do this mod so you can easily drop it.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Tie rod thru oil pan [Re: '72CudaRacer] #551130
12/11/09 02:57 PM
12/11/09 02:57 PM
Northwest Chicago Suburb
DaDart Offline
DaDart  Offline
There is a guy that make bushing to go in so that they can be removed easier. I've see him at the Indy show in March for the past couple years. I will try to look for his flyer when I get home.
3 Darts and a Ram
Re: Tie rod thru oil pan [Re: DaDart] #551131
12/11/09 03:13 PM
12/11/09 03:13 PM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
QUICKLINX, Never use a tie rod seperater or "pickle fork" again. Used by the not so famous "Hemi Fred" as well as others. Several SS/AH cars have his stuff. Call Mike Roth at MR2 Performance. 765 483 9371. Tell him Frito sent ya.
Re: Tie rod thru oil pan [Re: HemiDart68] #551132
12/11/09 03:16 PM
12/11/09 03:16 PM
Mooresburg, Tn
Mooresburg, Tn
Do you modify the center link (all 4 joints)? I'm assuming you machine the center links from tapered to straight? and use the bushing on the taped shank of the joint?
Do you have a web site for MR2?
Thanks, Brian
Re: Tie rod thru oil pan [Re: '72CudaRacer] #551133
12/11/09 03:18 PM
12/11/09 03:18 PM
Mooresburg, Tn
Mooresburg, Tn
Sorry Frito, you posted at the same time as my follow up. Thanks, Brian
Re: Tie rod thru oil pan [Re: '72CudaRacer] #551134
12/11/09 03:24 PM
12/11/09 03:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mine comes apart pretty easily, but it's been that way for decades and has been apart & back together God knows how many times. It's no big deal, I can have the pan off & back on in under 20 minutes, including turning the crank so the counterweight clear the pan flange (I marked that position on the balancer), and I take my time (translation: old & slow!).
Re: Tie rod thru oil pan [Re: topside] #551135
12/11/09 03:39 PM
12/11/09 03:39 PM
KYbywayof WV
Frito Offline
Frito  Offline
KYbywayof WV
Brian, tried to send a PM but it says your not accepting. I think we spoke at Clay City. A guy there had Quicklinx installed. www.mr2performance.com If you get a set, tell Mike I will foego my commision.
Re: Tie rod thru oil pan [Re: Frito] #551136
12/11/09 04:21 PM
12/11/09 04:21 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
I've got the drag link bushings in stock, let me know if you need some Thanks, Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Tie rod thru oil pan [Re: Frito] #551137
12/11/09 06:06 PM
12/11/09 06:06 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Not to change the topic,,,,but I noticed some mention of Clay City/Kentuckey in this thread. I used to race at River City/Rt#5 with David and Satch Brown. I heard David had an accident, but have lost contact with all of these guys...anybody know them or have any updates on them??
If you like drag racing, support your local track.
Re: Tie rod thru oil pan [Re: WILD BILL] #551138
12/11/09 06:33 PM
12/11/09 06:33 PM
CHANDLER, AZ
512 VALIANT Offline
512 VALIANT  Offline
CHANDLER, AZ
Wild Bill is correct everything goes through the pan, depending on what kind of access you have its not that bad. I'm at work right now, but if you look at the post that says Engine installed in Valiant (page 2-3) you can see my pan in 1 of the pics. My whole front end comes off so its easy for me. And a pickle fork is a must to remove the center link if its been on there a while esp for the first time after that they are not as bad. I had to relocate the hole in my pan (milodon) due to engine set back. The 440 source also makes a pan w/ hole in it.
Re: Tie rod thru oil pan [Re: '72CudaRacer] #551139
12/11/09 07:23 PM
12/11/09 07:23 PM
AndyF Offline
AndyF  Offline
If you use the correct tool (which isn't a pickle fork) then the center rod comes off really quick. I used to run the center rod thru the oil pan on my car and it would only take a couple of minutes to pop it loose. Just need to use the correct tool per the service manual. A pickle fork just tears up the ends and ruins the seals.
Re: Tie rod thru oil pan [Re: AndyF] #551140
12/11/09 07:27 PM
12/11/09 07:27 PM
CHANDLER, AZ
512 VALIANT Offline
512 VALIANT  Offline
CHANDLER, AZ
That is correct, I have modified my "pickle fork" so it does not damage the boots.
Re: Tie rod thru oil pan [Re: mr2performance] #551141
12/13/09 02:33 AM
12/13/09 02:33 AM
Mooresburg, Tn
Mooresburg, Tn
Thanks for the info guys. Mike, what has to be done to the center link to run your bushings and approx cost?
Thanks, Brian
Re: Tie rod thru oil pan [Re: CHAPPER] #551142
12/13/09 02:42 AM
12/13/09 02:42 AM
Mooresburg, Tn
Mooresburg, Tn
Chapper, can't help with info, my first time to Clay City(4 hour tow). Maybe one of the local guys can help.
Brian
Post deleted by Defbob [Re: '72CudaRacer] #551143
12/13/09 03:37 AM
12/13/09 03:37 AM
Re: Tie rod thru oil pan #551144
12/13/09 08:28 AM
12/13/09 08:28 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Drill it 23/32" and ream it .750"!
SS/DA 1924
Re: Tie rod thru oil pan [Re: SSDAcuda] #551145
12/13/09 11:53 AM
12/13/09 11:53 AM
Lebanon,IN
Lebanon,IN
Don't say "ream" around Fred!
Re: Tie rod thru oil pan [Re: mr2performance] #551146
12/13/09 01:06 PM
12/13/09 01:06 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
SS/DA 1924
