Re: Tie rod thru oil pan
[Re: '72CudaRacer]
#551128
12/11/09 02:44 PM
12/11/09 02:44 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
It's the center link that goes through the pan and although I haven't used one, I don't see how you could make it easier to come apart. Everything that bolts to it is a tapered press fit.
A tie rod seperating tool might make the job easier.
[Re: WILD BILL]
#551129
12/11/09 02:56 PM
12/11/09 02:56 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
MR2 chassis sells a bushing that can go in there to make it so the sterring link drops on and off. Most of the Superstock guys do this mod so you can easily drop it.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: topside]
#551135
12/11/09 03:39 PM
12/11/09 03:39 PM
Posts: 1,607 KYbywayof WV
Frito
KYbywayof WV
Brian, tried to send a PM but it says your not accepting. I think we spoke at Clay City. A guy there had Quicklinx installed. www.mr2performance.com If you get a set, tell Mike I will foego my commision.
[Re: Frito]
#551136
12/11/09 04:21 PM
12/11/09 04:21 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
I've got the drag link bushings in stock, let me know if you need some Thanks, Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: Frito]
#551137
12/11/09 06:06 PM
12/11/09 06:06 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Not to change the topic,,,,but I noticed some mention of Clay City/Kentuckey in this thread. I used to race at River City/Rt#5 with David and Satch Brown. I heard David had an accident, but have lost contact with all of these guys...anybody know them or have any updates on them??
If you like drag racing, support your local track.
[Re: WILD BILL]
#551138
12/11/09 06:33 PM
12/11/09 06:33 PM
Posts: 136 CHANDLER, AZ
512 VALIANT
CHANDLER, AZ
Wild Bill is correct everything goes through the pan, depending on what kind of access you have its not that bad. I'm at work right now, but if you look at the post that says Engine installed in Valiant (page 2-3) you can see my pan in 1 of the pics. My whole front end comes off so its easy for me. And a pickle fork is a must to remove the center link if its been on there a while esp for the first time after that they are not as bad. I had to relocate the hole in my pan (milodon) due to engine set back. The 440 source also makes a pan w/ hole in it.
[Re: AndyF]
#551140
12/11/09 07:27 PM
12/11/09 07:27 PM
512 VALIANT
CHANDLER, AZ
If you use the correct tool (which isn't a pickle fork) then the center rod comes off really quick. I used to run the center rod thru the oil pan on my car and it would only take a couple of minutes to pop it loose. Just need to use the correct tool per the service manual. A pickle fork just tears up the ends and ruins the seals.
That is correct, I have modified my "pickle fork" so it does not damage the boots.
Post deleted by Defbob
[Re: '72CudaRacer]
#551143
12/13/09 03:37 AM
12/13/09 03:37 AM
[Re: SSDAcuda]
#551145
12/13/09 11:53 AM
12/13/09 11:53 AM
mr2performance
Lebanon,IN
Don't say "ream" around Fred!
765 483 9371
#551147
12/13/09 01:20 PM
12/13/09 01:20 PM
Posts: 2,039 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Thanks for the pics H Fred. Makes a lot of sense now. Mike I'll get with you in the few days/week about ordering them. Thanks again guys. Brian Dunnigan
[Re: '72CudaRacer]
#551148
12/13/09 01:22 PM
12/13/09 01:22 PM
#551149
12/13/09 01:26 PM
12/13/09 01:26 PM
Posts: 2,499 God's Country Maryland
GODSCOUNTRY340
A couple hard raps on the centerlink where the tierod goes through always pops mine loose. Don't hammer the tierod, hammer the centerlink.
