Re: Good Max wedge ported heads for budget engin build?!
[Re: dodgeboy11]
#550756
12/11/09 02:55 AM
12/11/09 02:55 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I had those heads (stage VI P5249579 Mopar performance heads) on my 528.. They are not good, or maybe closer to crap ootb.. Don't waste your money going that way. While they will make good power when finished, you'll have far more $$$ in them than if you went Victor MW.. from experience. I had $5000.00 in those heads.. Car went 9.20's @ 145 in good air @ #2900 w/ a glide and a spragless 9".. But I could have had a real nice set of B1's for that $$$.. Chris..
[Re: Jonnyj00]
#550757
12/11/09 07:14 AM
12/11/09 07:14 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
jonnyj00, By this time tomorrow, everyone will be all over this, trying to turn it into a war of brands, and almost none of them will look at, or care about, what your goals, budget, or proposed combination really are. Tell us about the car: is it currently running? Stuts, or A-arms? 4 link or ladder bar? Have headers? If so, what size, and do they have room to move up for raised port heads? What does the car weigh, what tranny? and what are your performance goals? Tell us about the engine: 440, so RB.. true 440 or stroked? Solid cam or roller? If you intend to use what you already have, what style pistons? Do you already have rockers? Budget?? what that word means is different for everyone! Can you afford $1000 to 1500 for reliable, proper valvetain gear? Can you afford port work? Can you afford to build another set of 1200$ custom headers? Now let the deliberations begin...I could give you examples of about 5 different engines, and the dollars spent vs. performance, but then one of our chevy drivers would come on here and call me an idiot..so I'll wait until you provide more info...meanwhile we'll listen to reccomendations ranging from "budget home ported 906's are all you need" to "why waste money on anything short of fully flowed Predators"...
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#550758
12/11/09 09:58 AM
12/11/09 09:58 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
bottom of the line Indy Ez's. port yourself to max wedge(easy to do). they will flow around 350 for about $2k standard rockers too so you could reuse what you have
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: B1Fish540]
#550760
12/11/09 11:47 AM
12/11/09 11:47 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Mopar Performance sells the Victor head with their own part number on it now. If you wanted an MP part(instead of the problematic Stage VI)
MP sells the RPM head with their part number and straight plugs instead of angle , when did they start offering the Victor ?
[Re: camdog440]
#550765
12/11/09 03:22 PM
12/11/09 03:22 PM
JohnRR
U.S.S.A.
Here's another thread about them a while back...
https://board.moparts.org/ubbthreads/showflat.php?Number=5420095
Thanks , I missed that thread .
[Re: JohnRR]
#550766
12/11/09 05:37 PM
12/11/09 05:37 PM
Jeff at MODERN CYLINDER HEAD is the guy for your heads. he's also running a winter special to save you some money. the other guy isn't. he knows how to get the optimum out of your heads, he also has a CNC machine which the other guy doesn't.
#550767
12/11/09 06:00 PM
12/11/09 06:00 PM
Posts: 3,095 Idaho
Runner
Idaho
and that makes the heads better how?
