440 Q: can i get away with the HD stamped rockers? #550430
12/10/09 05:57 PM
12/10/09 05:57 PM
Clinton Twp. Michigan
coronet1966d Offline OP
im running a .020 over 440 with 10:1CR edelbrock RPM heads and intake with the comp XE275HL cam, do you guys thing i can get away with the mopar HD stamped rockers and shafts? id much rather spend $87 than $487 if i can get away with it
also what are the correct lenght pushrods? for my hydraulic cam application?
thanks in advance
Re: 440 Q: can i get away with the HD stamped rockers? [Re: coronet1966d] #550431
12/10/09 06:05 PM
12/10/09 06:05 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You'll be fine. I'm running stock mid 70's pushrods and rockers on a lunati voodoo 60303 which is not far in spec from the 275hl. Some guys have said the HD rockers are the same as the mid 70's rockers. Also other guys are running stock rockers with considerably more lift and/or duration than the 275hl.
Re: 440 Q: can i get away with the HD stamped rockers? [Re: DaytonaTurbo] #550432
12/10/09 06:13 PM
12/10/09 06:13 PM
ok good. i still have the rockers and shafts off my 452 heads i may just clean those real well and reuse them. ive never really liked adjustable rockers anyway
where can i get standard pushrods? or what lenght and ball configuration am i looking for?
Re: 440 Q: can i get away with the HD stamped rockers? [Re: coronet1966d] #550433
12/10/09 06:54 PM
12/10/09 06:54 PM
Manitoba, Canada
Manitoba, Canada
Regular pushrods just have the rounded ball end on both sides. I'm sure you can get some used stockers for cheap or buy some new one for cheap from 440source.
Re: 440 Q: can i get away with the HD stamped rockers? [Re: coronet1966d] #550434
12/10/09 09:02 PM
12/10/09 09:02 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
You should be more concerned with the spring pressure. Those stamped steel rockers can't handle much more spring pressure than stock springs. I learned the hard way on a 440 GTX I owned when I was your age. The result was 2 bent pushrods,a rocker arm with the pushrod cup missing and a blown head gasket.
If you think your build was expensive just wait till you see the cost to fix it when it breaks due to short cuts and inferior parts
Re: 440 Q: can i get away with the HD stamped rockers? [Re: ccdave] #550435
12/10/09 09:07 PM
12/10/09 09:07 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
But I think you should still be ok unless you want to rev to the moon.
Re: 440 Q: can i get away with the HD stamped rockers? [Re: coronet1966d] #550436
12/10/09 09:36 PM
12/10/09 09:36 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I am using the HD stamped rockers (purchased around 2006) on Edelbrock heads/springs, with a .501 lift, 245 duration cam (Isky) and haven't had any problems, though I haven't put lots of miles on it.
When I was deciding which rockers to use, I remember seeing an online article by a mopar magazine, they had used I think one of the Comp Cams hi lift cams and used stamped rockers. There was a comment that they are plenty strong, or something along those lines. Anyways, no problems here.
Re: 440 Q: can i get away with the HD stamped rockers? [Re: Exit1965] #550437
12/10/09 09:41 PM
12/10/09 09:41 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
right here:http://www.moparmusclemagazine.com/techarticles/mopp_0209_383_engine_restore/index1.html
Re: 440 Q: can i get away with the HD stamped rockers? [Re: forphorty] #550438
12/10/09 09:45 PM
12/10/09 09:45 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I ran Comps 525 Hyd cam for a long time W/ the factory rockers. Never had a problem.
Re: 440 Q: can i get away with the HD stamped rockers? [Re: coronet1966d] #550439
12/10/09 10:05 PM
12/10/09 10:05 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I ran the same cam with HD rockers and it kept spitting push rods. The ramps are very aggressive on that cam. I even tried SmithBros for a perfect fit and had the same problem. Changed to adjustable rockers and solved the problem. Lucky no damage.I ran cams with more lift...old style, and had no problems.
Re: 440 Q: can i get away with the HD stamped rockers? [Re: R/T1968R/T] #550440
12/11/09 03:46 AM
12/11/09 03:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran used stock rockers on a 383 with the MP .484 cam for just over 7 years with zero problems. Plenty of street miles and I raced the car a few times a year. Ron
Re: 440 Q: can i get away with the HD stamped rockers? [Re: coronet1966d] #550441
12/11/09 09:59 AM
12/11/09 09:59 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Using factory 1976 rockers with zero problems on a built 440.
Re: 440 Q: can i get away with the HD stamped rockers? [Re: Commando1] #550442
12/11/09 12:04 PM
12/11/09 12:04 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Summit has the push rods for like 30 bucks.My kid has them in his 62 413.Just put new TRW rocker on last year when we put my 516s with the heavier Comp springs on.He had been running the stock 62 rockers with the Hughes cam with my old Isky springs for 8 years with no problems.The stock Eddy springs arent very stout anyway.Rocky
Chrysler Firepower
Re: 440 Q: can i get away with the HD stamped rockers? [Re: therocks] #550443
12/11/09 12:46 PM
12/11/09 12:46 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
There is more chance of severe damage to pushrods and rockers with too little spring pressure than a little over what you need.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 440 Q: can i get away with the HD stamped rockers? [Re: Rapid340] #550444
12/11/09 05:47 PM
12/11/09 05:47 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
Make sure you get the springs for the cam you are running or have the Pressure checked. I always tried to find a set off a lower mile 400 or 440 because the Rockers do get thin with a lot of miles and will push through. Make sure the Shafts are not scarred from the Rockers also. New ones are cheap compared to damage if something binds up or lets loose.
