Do these look ported to you? #550256
12/10/09 01:25 PM
12/10/09 01:25 PM
IL
furious70 Offline OP
IL
516's, 2.14/1.81's
These are supposed to be full ported, no exact numbers, but north of 270/190. Not quite what I was expecting when I opened the box.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Do these look ported to you? [Re: furious70] #550257
12/10/09 01:28 PM
12/10/09 01:28 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
barely. looks like a clean up is all.
Re: Do these look ported to you? [Re: mopar dave] #550258
12/10/09 03:19 PM
12/10/09 03:19 PM
organ
maximum entropy Offline
organ
Re: Do these look ported to you? [Re: maximum entropy] #550259
12/10/09 03:24 PM
12/10/09 03:24 PM
Renton Washington
Triple Threat Offline
Renton Washington
Sounds like an internet deal gone south. Might be worth the few bucks to get one flowed and see how bad they really are, that will at least give you some ammo against the seller.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Do these look ported to you? [Re: Triple Threat] #550260
12/10/09 03:29 PM
12/10/09 03:29 PM
IL
IL
bought them off here, within a 4hour drive, so if worse comes to worse....
I'm giving the benefit of the doubt to start, awaiting for info on who did the work. Also have a call into the closest shop around here that can do flow testing on prices to get an idea if they are any better than stock, yes.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Do these look ported to you? [Re: furious70] #550261
12/10/09 04:22 PM
12/10/09 04:22 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Not sure if you were shopping for ported or unported heads?
At any rate regardless of how much (or little) those heads have been ported, the fact is that they are definately ported to some extent.
If they were sold as "unported" there's a problem for the seller, if they were sold as "ported" then things lean towards the buyer possibly not asking enough questions about flow etc. or requesting enough pictures before pulling the trigger.
Re: Do these look ported to you? [Re: ScottSmith_Harms] #550262
12/10/09 04:26 PM
12/10/09 04:26 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
Not 'well'!
Re: Do these look ported to you? [Re: ScottSmith_Harms] #550263
12/10/09 04:32 PM
12/10/09 04:32 PM
IL
IL
while the exact flow sheets were not available, they were sold as heavily ported by a professional and some 1/4mi times and vehicle info was shared that I didn't think could be obtained with substantially unported heads.
I didn't get any pictures ahead of time (in hindsight an error), mostly because it was claimed the port job was done by a guy from a professional shop that is on here (not going to name them, as they had no part in the sale and there's no need to drag them in here).
Local shop here wants $150 to just check a few ports to see where we're at, is that the going rate? I don't need a full workup done, I just need to see 2 intakes/2 exh to see what they are.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Do these look ported to you? [Re: furious70] #550264
12/10/09 04:39 PM
12/10/09 04:39 PM
under a rock
flathood Offline
flathood  Offline
under a rock
Those are the before pictures,right???
Re: Do these look ported to you? [Re: flathood] #550265
12/10/09 05:10 PM
12/10/09 05:10 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
they look ported to me with an untouched floor. they are not going to look like a -1 head
Re: Do these look ported to you? [Re: sixpackgut] #550266
12/10/09 05:13 PM
12/10/09 05:13 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
thats what I thought too....
Re: Do these look ported to you? [Re: Quicksilver440] #550267
12/10/09 05:16 PM
12/10/09 05:16 PM
IL
IL
I have never ported a set myself, so I am a novice for sure. What concerned me right off the bat is what looked like a lot of untouched rough casting walls, which would mean they weren't touched.
Like I said, I'm not going off on the guy yet, I'm just trying to reconcile what I see vs. what I thought I bought. I'll be pleased as punch if these actually do flow well, as that's what I want and what I paid for!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Do these look ported to you? [Re: furious70] #550268
12/10/09 05:55 PM
12/10/09 05:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I feel for you in that you expected more than you recieved, but quite frankly I don't think you did enough homework before you bought them. I don't see how flow testing them now will give you any leverage against the seller unless he claimed specific numbers or specific porting work before you bought them, all of the other info you posted concerning race car numbers etc.are subjective.
Re: Do these look ported to you? [Re: ScottSmith_Harms] #550269
12/10/09 06:06 PM
12/10/09 06:06 PM
IL
IL
I appreciate that, but I wasn't asking whether anyone thinks I have recourse with the guy, I was asking if any experienced guys can tell by my blurry cam shots here whether I got anything near what I was told they were (trying this first before spending more money to verify). I'm a big boy and will live with whatever the outcome. Whether they are decent heads or not will depend if I spend more money on a project, so having them flowed is as much to see where I'm at now as anything.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Do these look ported to you? [Re: furious70] #550270
12/10/09 06:15 PM
12/10/09 06:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I guess that's where I'm a bit lost here. It doesn't seem clear as to exactly what you were told regarding the details of the porting work. As far as his description, based on what you posted a few posts back he used fairly general terms in describing the work that's been done and not much in the way of specifics.
All that aside I'd say that what you ended up with are a set of 516 heads with bigger valves and a clean up porting job in the intake runners and not much else, the resulting flow would probably amount to what you would get out of a basically stock set of 915 heads.
Are they decent heads? Probably once they have a fresh valve job put on them, question is, are the "decent" enough to give you the amount of flow get your cars combo to perform like you'd hoped? Hard to say giving the info we have so far.
Re: Do these look ported to you? [Re: furious70] #550271
12/10/09 06:22 PM
12/10/09 06:22 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Considering they're still assembled and have lots of "stuff" in the ports, it's not clear exactly what's been done to 'em. Strip them down, get the "stuff" out of the bowls & the runners, and take some pics where you actually show what's been done (if anything) in the valve bowls, etc.
Re: Do these look ported to you? [Re: furious70] #550272
12/10/09 06:32 PM
12/10/09 06:32 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
516's, 2.14/1.81's
Were they complete with valves and fresh or used?
Have you run them yet?
Who said north of 270/190 and @ what lift?
What was the price if you don't mind me asking.
Re: Do these look ported to you? [Re: BradH] #550273
12/10/09 06:33 PM
12/10/09 06:33 PM
Idaho
Runner Offline
Runner  Offline
Idaho
Re: Do these look ported to you? [Re: furious70] #550274
12/10/09 06:58 PM
12/10/09 06:58 PM
N. IL
tntmachine Offline
tntmachine  Offline
N. IL
CC an intake and an exhaust port and compare to stock. Then take the valves out and see if there has been any work done in the bowl area. Stock head flow can be improved considerably by "pocket porting".
Re: Do these look ported to you? [Re: tntmachine] #550275
12/10/09 09:02 PM
12/10/09 09:02 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
how the heck can you tell from those pictures?
you need to get the crud out of there..
and show a picture of the bowl and or guide..
looks from the tiny bit i can see that .
there is porting on the pushrod pinch..and porting around the roof/guide..but its hard to tell..for sure..
pop a keeper off and pull a valve...
i will say this much the motor they came off of..
either had no ring seal..or the carb was missing a bunch of screws...that thing is carbon rich..
or maybe they ran it on diesel fuel.?
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
