Jeep transmission shift problem, auto. #550191
12/10/09 11:03 AM
12/10/09 11:03 AM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
1999 Jeep Grand Cherokee with 4.0 straight six and automatic. (86,000 miles). Only on cold mornings, second gear winds out for a long time and then when it finally shifts into third the transmission free-wheels as if in neutral. I have to let off the throttle to get it to go into third. After the trans warms up this problem quits. The rest of the day it shifts normal. Please let me know what could be causing this. Thank You.
Re: Jeep transmission shift problem, auto. [Re: 340Scamp] #550192
12/10/09 01:12 PM
12/10/09 01:12 PM
Indy
rtse70 Offline
rtse70  Offline
Indy
Same problem with a 2000 Grand Cherokee. One mechanic wanted $1700 to replace the trans!! I've had people tell me the bands can be replaced/adjusted and may fix it. I just went to store got some Lucas Oil Transmission Fix, and gets me through the winter months until it runs without problems in warmer weather.
Re: Jeep transmission shift problem, auto. [Re: 340Scamp] #550193
12/10/09 01:27 PM
12/10/09 01:27 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
alot of my customers who dont run the atf+4 chrysler fluid have that problem. if your running dex/merc fluid switch it out and try the +4.
71 scamp big block with 915 heads 727 trans
Re: Jeep transmission shift problem, auto. [Re: 340Scamp] #550194
12/10/09 08:17 PM
12/10/09 08:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the filter isn't restricting flow, the problem is hardened/shrunk seals in the front clutch, once the fluid warms up the seals soften enough to seal.
An additive like Trans-X or Lucas will soften the hardened seals.
