Page 2 of 3 1 2 3
Re: Small Block Edelbrock Heads [Re: Streetwize] #549940
12/11/09 02:32 AM
12/11/09 02:32 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
With a valve job and port work on some Eddy magnum heads I saw 282 cfm. It was enough air for 498 hp out of a 360 with about 10.5:1 compression and a hydraulic roller. My own personal motor has the earlier LA heads and they have more meat in the ports for a little more aggressive port, but they don't flow as "easy", in my experience, as the magnum versions. I've currently got mine flowing 312 cfm @ .700" with a 2.080" intake valve. I've plugged the pushrod holes and plan on using offset rockers. Problem is, at the amount of effort I'm putting into the eddies, I could have done some Indys. But, I already had the E's. Just can't get enough cross section out of them to flow the big numbers.
We've got a hydraulic roller'd 408 with some oval indy's I ported on the dyno right now. I hope to get it running tomorrow, but it'll probably turn into next week with the other work that needs to be done.
Guess I'll throw my hat into the ring. I've got more experience porting the E's than I sometimes like, but I seem to have a God given talent for getting them to flow air.
Number's in the signature if you're interested.
Jason.
They say a picture's worth a thousand words. Well here's a few thousand words.
little wave in my port's wall, not finished yet.
Re: Small Block Edelbrock Heads [Re: meus31] #549941
12/11/09 03:37 AM
12/11/09 03:37 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
all right i have a question . what is the best anyone has ever seen or had a edelbrock run at the track. pump gas or race fuel just tell us what it was so we can compare apples to applesand race weight if you know it.
ive ran a 10.24 at 130 3000lbs race weight, jeff at modern cyl head cnc ported the heads, bigger valves too, didnt do too much tuning as of yet just having fun, lonnie (wheelsup68) still or has ran eddy heads on a smallblock well into the nines, a bit lighter than me, mabey on alky?? not sure, if your gonna spend the coin to go fast low 10 or in the nines id get a better head
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Small Block Edelbrock Heads [Re: meus31] #549942
12/11/09 08:48 PM
12/11/09 08:48 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
We have run a best of 6.15 in the 1/8 @109 in good air with 416, 750 holley and 557 Solid and Shady Dell Eddies , Flowed 290's Car was about 2980lbs. I'd say that is at least a 9.80 or better
Re: Small Block Edelbrock Heads [Re: Lil Wedge] #549943
12/11/09 09:20 PM
12/11/09 09:20 PM
utica ny
meus31 Offline
meus31  Offline
utica ny
LIL Wedge what kind of compression does your car have and any convertor specs . is that with a mopar performance 557 solid lift cam?
Re: Small Block Edelbrock Heads [Re: meus31] #549944
12/11/09 09:30 PM
12/11/09 09:30 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
it's got Ross 12.5-1 pistons with 63 cc chambers, Converter is 8 in, about 5300 stall, Racer Brown cam
Re: Small Block Edelbrock Heads [Re: Lil Wedge] #549945
12/12/09 09:05 AM
12/12/09 09:05 AM
utica ny
meus31 Offline
meus31  Offline
utica ny
lil wedge thats a great running combo .
Re: Small Block Edelbrock Heads [Re: meus31] #549946
12/12/09 10:44 AM
12/12/09 10:44 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Ive run my eddies for 3 years .
2 years on my 410 had some port work and a 557 cam with 1.6 rockers
best average 10.30s
built a 418 this year more port work ,work on valve cuts now 590 cam 1.6 rockers .
best average 10.10s
THEN I added low gear got me in 9s
Good heads just don't get the flow numbers up thier .
I like to get some heads that flow to do a 418 up cubic inch .
my car 2860 ,3040 w/me
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Small Block Edelbrock Heads [Re: MarkKirby] #549947
12/12/09 11:13 AM
12/12/09 11:13 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Mark,
As good as your car runs and your power is with the J's, my gut is the eddies (even with a full tilt port job) may not be large enough of an ET drop to make you happy.
I think you'll need to see 320 cfm to really make you smile, I would strongly consider either a W5 or a brodix to get more CFM and Intake port CC (which is what the big motor needs). You can only get so much fuel through a port.
WIZE
In Car:
Re: Small Block Edelbrock Heads [Re: Streetwize] #549948
12/12/09 12:11 PM
12/12/09 12:11 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Mark,
or one of the indy 360 variants...
2017 Grand Cherokee Overland
Re: Small Block Edelbrock Heads [Re: patrick] #549949
12/12/09 07:59 PM
12/12/09 07:59 PM
Bakersfield, CA
MarkKirby Offline OP
Bakersfield, CA
It seems I've got a little more weight than most of you for a Duster. Kind of tough to cut it down since I'm pushing 330 without the race car!!!! I could lay off the enchiladas and learn to like broccoli and probably pickup a few hundredths!
The thing I'm struggling with is that obviously the Indy kit brings forth the most power at about $4000...the Eddies(from Indy) are still $3700(quoted by Indy) for quite a bit less power upgrade. Although I don't need as much power gain as the Indy 360 will provide it doesn't seem to make economic sense to buy the Eddies unless I can find a similar package at a heck of a lot less than Indy quoted.
I don't want to run 9.99 in this car. I DO want to pickup a few mph and a couple tenths which probably translates to 50-60hp.
Mark & Nancy Kirby 1971 Plymouth Duster The Grape Ape 10.20 @129mph 1.32 60'
Re: Small Block Edelbrock Heads [Re: MarkKirby] #549950
12/12/09 08:18 PM
12/12/09 08:18 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Do you know the Sloan brothers, I think they maybe selling the top end off their current motor, Brian at IMM did the heads so you can't go wrong there.
Re: Small Block Edelbrock Heads [Re: MarkKirby] #549951
12/12/09 09:02 PM
12/12/09 09:02 PM
SoCal
Brian Hafliger Offline
SoCal
Just don't plan on picking up any HP if you use Indy's kit with OOTB -1 heads...
those heads don't make any more HP than eddy heads OOTB. They flow 260 cfm MAX on my bench!!
They NEED porting to work like they should.
Change the cam, ported eddy heads and your super victor intake and your going to go 10.teens I guarantee it!
Brian Hafliger
Re: Small Block Edelbrock Heads [Re: Brian Hafliger] #549952
12/13/09 03:09 AM
12/13/09 03:09 AM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
Mark, dont do the CNC stuff. Buy the Edelbrocks and have Brian @ IMM port them and pick out a cam to compliment the new heads. Your intake, rockers and headers will bolt right up making it the most economical choice. Indy heads will be WAY more money just because you wouldnt be able to utilize anything on your current top end. I would sell you the Eddies off of Dougs engine, but Im using them on my wifes hotrod once I finish up DOugs new 411 Indy headed engine with some IMM port work. Mark, what did you end up doing with your superstock 340 engine?
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Small Block Edelbrock Heads [Re: PUNK] #549953
12/13/09 09:26 AM
12/13/09 09:26 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I think he's re-using the cam.
Re: Small Block Edelbrock Heads [Re: S/ST 3040] #549954
12/13/09 09:45 AM
12/13/09 09:45 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
AGAIN,
I dont know who you are talking to at Indy but I just bought a set. Heres the link. They are $2500 for the topend kit.
http://chucker54.stores.yahoo.net/inedenalhe.html
And this is from Indy's site direct.
http://indyheads.com/images/p_pge/price13.pdf
Re: Small Block Edelbrock Heads [Re: Brian Hafliger] #549955
12/13/09 11:19 AM
12/13/09 11:19 AM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
is the super victor that much better than the victor 340 with eddys in a combo like he running? Just asking, thats all. Just want to see if I am leaving any power on the table.
Re: Small Block Edelbrock Heads [Re: Hunted Duck] #549956
12/13/09 11:35 AM
12/13/09 11:35 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
The Super Victor picked me up a tenth. BUT, the AirGap I have was faster than the regular Victor and the Mopar M1 on mine. The Super Victor was the best on mine.
Re: Small Block Edelbrock Heads [Re: Hunted Duck] #549957
12/13/09 11:40 AM
12/13/09 11:40 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Not to hijack i put my 2 cents in on heads.
What are others seeing if any in the SUPER VICTOR INTAKE ?
I'm running the victor 340 with super sucker .
wanting to buy it if the gain justify's the cost .
Also in what stage's of port work .
they are pricey from hughe's .
Going on my 418 .
thanks don
Re: Small Block Edelbrock Heads [Re: DaKuda] #549958
12/13/09 11:43 AM
12/13/09 11:43 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
i type too slow
dakuda is that oootb or ported to what degree ?
thanks DR
Re: Small Block Edelbrock Heads [Re: 10 o to go] #549959
12/13/09 11:46 AM
12/13/09 11:46 AM
P
PUNK Offline
PUNK  Offline
P
When the Edelbrocks were stock and unported, we used a Mopar M1 manifold. We then had the heads ported by Brian @ IMM and at the same time I switched to the Super Victor. THe car went from 11.20s to 10.60s. I wish I would have done the manifold swap after running the ported heads. So basically I cant even give an honest conclusion as the affects of the manifold vs. another one. We have a 2" tapered spacer ontop as well and the manifold is TALL.
Page 2 of 3 1 2 3
